How is Efficiency of Heat Exchangers (HRV) determined
  • Context: Undergrad
  • Thread starter Thread starter whatmough
    Efficiency Heat
The efficiency of Heat Recovery Ventilators (HRV) can reach up to 85% due to the use of countercurrent flow heat exchangers, which theoretically can achieve 100% efficiency. However, real-world applications never reach this peak due to various factors, including ambient temperature conditions. For instance, the efficiency of heat pump systems significantly declines below 45°F (7.2°C). Understanding these dynamics is crucial for optimizing HRV performance in residential settings.
  • Knowledge of countercurrent flow heat exchangers
  • Understanding of heat recovery ventilator (HRV) specifications
  • Familiarity with ambient temperature effects on HVAC systems
  • Basic principles of thermodynamics related to heat exchange
  • Research the design principles of countercurrent flow heat exchangers
  • Investigate the impact of ambient temperature on heat pump efficiency
  • Explore advanced HRV technologies and their specifications
  • Learn about thermodynamic cycles in HVAC systems
HVAC engineers, energy efficiency consultants, and homeowners interested in optimizing the performance of heat recovery ventilators.
whatmough
I've be looking at the specs for Heat Recovery Ventilators (HRV).
They commonly state that they can recover 85% of the heat. How is that possible? To me you could only every recover 50% in a perfect situation because of the equal volume of airflow's. Won't the air temperatures just stop at equilibrium?
Science news on Phys.org
Commercially designed heat exchangers must be designed with a fairly strict operating (especially ambient environmental) temperature window in mind to keep to high levels of efficiency. The common household so-called "heat pump" systems efficiency drops precipitously below 45 F (7.2C) for example.
Thanks a lot Aleph you answered my question, that wiki was helpful.
  • · Replies 19 ·
