How is exp(tL) rigorously defined in Duhamel's formula?
  • Context: Graduate
  • Thread starter Thread starter Yugo
    Formula
5 replies · 8K views
Yugo
Hello,
I am having trouble understanding how to use Duhamel's formula as a contraction to give existence uniqueness theorems for certain semi linear PDE.
To be more precise, have a look at the PDE and corresponding Duhamel formula in the wikipedia link given below:
http://tosio.math.toronto.edu/wiki/index.php/Duhamel's_formula
How is the exp(tL) even rigorously, defined? I can't find this anywhere.
L here is a differential operator. Exponentials of operators, like exponentials of matrices, are defined through the Taylor's series for ex:
[tex]e^L= I+ L+ \frac{1}{2}L^2+ \cdot\cdot\cdot + \frac{1}{n!}L^n+ \cdot\cdot\cdot[/tex]
where the powers mean repeated application of the operator and "I" is the identity operator. Of course, that should be applied to some function:
[tex]e^L(f)= f+ L(f)+ \frac{1}{2}L^2(f)+ \cdot\cdot\cdot + \frac{1}{n!}L^n(f)+ \cdot\cdot\cdot[/tex]
That is typically very difficult (or impossible) to evaluate for all but self-adjoint operators.
I see. So for example, that thing would make sense if the operator L was a Laplacian?
Moreover, if that's the case, could you possibly give me an example of using that Duhamel formula as a contraction to solve a PDE problem? I've seen this sort of thing before for PDEs like the one above with u being a function of two variables and L the corresponding (spatial) laplacian, but I didn't understand how to show that the duhamel formula has a fixed point iff the PDE problem had a solution.
HallsofIvy, that is not difficult like you see! by semigroupe theory the expression [tex]e^{tL}f[/tex] is the solution of the differential equation on Banach space : [tex]u'+Lu=0, u(0)=f[/tex], so for example for the laplacian,
[tex]e^{t\Delta}f[/tex] is the solution of the Heat equation (for Dirichlet or Neumann conditions) which is the gaussian kernel:wink:
