How Is Maximum Acceleration of a Racecar Calculated Using Physics Formulas?
  • Thread starter Thread starter decerto
    Acceleration Max
The discussion revolves around calculating the maximum acceleration of a racecar using physics principles, specifically focusing on forces, torques, and friction. The problem involves analyzing the dynamics of a racecar, particularly the role of the rear and front wheels in the context of acceleration and frictional forces.
  • Participants explore the relationship between forces acting on the wheels and the resulting acceleration. Questions arise regarding the coefficient of friction for the wheels, the implications of "rolling without slipping," and the appropriate choice of reference points for torque calculations.
The discussion is active, with participants providing insights into the dynamics of the racecar. Some guidance has been offered regarding the use of static versus kinetic friction and the importance of including all relevant forces in moment calculations. Multiple interpretations of the problem are being explored, particularly concerning the choice of axes for torque analysis.
Participants note constraints such as the lack of explicit information about the moments of inertia of the wheels and the implications of different assumptions regarding the forces acting on the car. The discussion reflects a range of perspectives on how to approach the problem effectively.
decerto
http://imgur.com/a/vA0H2
$$F=ma$$
$$r \times F = I \alpha $$
Denoting the forces at the back wheel with a 1 and front wheel with a 2 and calculating the torques around the CoM I have
$$F-f_1-f_2 = mA$$
$$N_1 + N_2 -mg = 0$$
$$hf_1 + h_f2 - hF +bN_1-aN_2=0$$
with $$f_i = \mu_i N_i$$
So just using this I can't seem to solve for A in terms of mu and g. I have some questions though, is mu the same for both wheels? The also mentions "rolling without slipping", am I meant I incorporate this somehow?, it doesn't give any explicit info and moments of inertias of the wheels so I don't see how.
Any help would be appreciated.
The torque is applied to the rear wheels only and the resultant force of that torque is ##F##. By definition, the force ##F## is also the friction force reacting to that torque. There is nothing on the front wheels other than the normal reaction to the weight ##Mg##.
The coefficient of friction for the front wheel does not matter.
If the back wheel tries to accelerate too fast, the front wheel will go up (see motorbikes doing that, or drag races going wrong). What is the acceleration where this happens? Does the back wheel have enough friction to support this acceleration?
Just so I am clear, Are you saying I just have
$$F=MA=\mu N_1$$?
$$F=MA=\mu N_1$$?
Yes. You are asked to find the acceleration. The only unknown is ##N_1##. Solve the free body diagram to find it as a function of ##\mu## and ##A##.
So I just use this and the other two equations
$$N_1 + N_2 = Mg$$
$$bN_1-aN_2 -h F =0$$
Just so I have this clear in my head, if it says "roll without slipping" this means there is no frictional force that resists the motion. Instead when a torque is applied to the wheel (like the back wheel) or a force is applied through the CoM (like the front wheel) the wheel exerts a force on the road due to friction which results in an equal and opposite force which accelerates the car forward?
No, it only means that you use the static friction coefficient. If it was slipping, there would be a relative motion between the tire and the ground, thus you would use the kinetic friction coefficient.
For you moment equation, note that you have introduce ##N_2## which is an unknown. To eliminate it, base your equation on the moments about the contact point at the front wheels and the ground instead. Then you should be able to isolate ##N_1##. Also don't forget that ##F = MA##.
So calculating the moments about the point of contact of the front wheel I got
$$(a+b)N - aMg=0$$
which gives
$$A_{max} = \mu g \frac{a}{a+b}$$
Is this correct?
The next part of the question asks
but my answer and all my formulas are independent of h and if I go back to using the moments about the CoM to obtain a formula for h, I get h=0
Why did you take the front wheel? Do you expect the car to rotate around the front wheel?
Where is the acceleration in this equation?
$$(a+b)N - aMg=0$$
Is this correct?
Nope. You are missing the ##MA## component.
Because I told him to.
I have
$$ F= \mu N=MA$$
$$N=\frac{MA}{\mu}$$
which is how I got
in my original post.
Or are you saying I missing an "MA component" from my torque equation?
The ##MA## vector creates a moment about the front wheel contact point. Take your time studying the free body diagram.
The MA vector is one which acts through the CoM?, you are not talking about the F acting at the point of contact of the backwheel?
Yes.
No.
Once again:
I understand what you are getting at but I don't understand why I need to include MA as a moment, what physical reason is there for it when the force F is clearly marked as acting at the base of the wheel.
edit * ok I can see the logic if we consider MA is a fictitious force due to it being a non-inertial frame, but I don't see how make sense of it in an inertial frame.
You know that ##Mg## is based on an acceleration? And you included it in your moment analysis? So why not include ##MA## as well?
The following is the free body diagram, Do ##\sum F_x##, ##\sum F_y## and ##\sum M## about point ##Z##:
Depending on the axis of rotation you choose to use, you can make one or more forces irrelevant. @jack action appears to be assuming an axis of rotation at the point of contact of the front wheel on the ground. [Not the choice I would have made, but it's viable]. With that axis of rotation in mind one has yet another choice...
1. Assume an inertial frame and note that the angular momentum of the race car is increasing in the counter-clockwise direction as the car accelerates leftward. [Note: key point about angular momentum -- it's not always about rotation!]
2. Assume an accelerating frame and note that the angular momentum of the race car is now constant but that there is a fictitious rightward inertial force acting on the center-of-mass of the race car.
@jack action has chosen option 2. Option 1 is equally viable.
Either way, there is still a net torque from the upward supporting force on the rear wheel and the downward force from gravity. Either way, the choice of rotation axis has made the frictional force of road on tire irrelevant to the angular momentum balance.
Or... choose the axis of rotation at the contact point on the rear wheel. Now you can ignore the supporting force from road on tire.
Or... choose an axis at the center of mass. Now the angular momentum is constant regardless of reference frame choice. But now the frictional force of road on tire becomes relevant.
Any choice will work and the analysis can proceed. But one needs to make a choice and see how the forces on the free body diagram work with that choice.
But that is the force we are looking for, why would we want to ignore it? The one we do not care about is the supporting force from road on front tire ##N_f##. With point ##Z##, both ##N_f## and ##F## are ignored, leaving us with ##MA##, ##Mg## and ##N_r##. You actually find ##N_r## with one equation (which should take less than 2 days to solve!).
jack action said:
The one we do not care about is the supporting force from road on front tire Nf
That's not entirely true. You need to use that this cannot be negative.
We are (or should be) looking for the condition where the front wheel is about to lift off the ground. In that condition, the entire weight of the car is supported by the normal force of road on rear wheels. One can determine that force, ##N_r## easily without writing down an equation for angular momentum.
At the condition where the front wheels are about to lift off the road, ##N_f## is already known to be zero. Accordingly, it does not contribute to the angular momentum balance. Choosing an axis of rotation at point Z under the front wheels causes one term to drop out of the angular momentum balance. But it is the term associated with N_f which is already known to be zero. There is no point in eliminating a term that is already zero.
This clears it up for me I think, dL/dt != 0 in the inertial frame and there is no MA 'force'?
decerto said:
This clears it up I think, dL/dt != 0 in the inertial frame and there is no MA 'force'?
Yes.
If you write down the equation for angular momentum balance in the inertial frame and then do so again for the accelerating frame, they should come out almost identical. You will have a term that moves from one side of the ##Σ\tau = \frac{dL}{dt}## equation to the other. In the inertial frame, that term is the ##\frac{dL}{dt}##. In the non-inertial frame, that term is the fictitious torque from ##Mah##.
By no coincidence, those two terms are equal and opposite.
I must admit that I understood the problem differently, especially when only part (a) was available. I thought you needed to determine the maximum acceleration given ##\mu## and ##g##, but also given ##a##, ##b## and ##h## (which is a much more interesting and realistic problem). This will give you a relationship to determine the maximum acceleration for any position of the c.m.
By studying this relationship and knowing the fact that the front wheels must remain on the ground at all times (which determines the maximum friction force you can ultimately get), you can find the c.m. locations that will produce the ultimate maximal acceleration for a given ##\mu## only. In any other location, either the front wheels will be off the ground or the maximum acceleration will be lower (but there is still a valid maximum acceleration).
10K
13K
