How is source-drain voltage defined?
  • Thread starter Thread starter mzh
    Voltage
The discussion clarifies the definition of source-drain voltage (V_SD), which is conventionally expressed as V_SD = V_S - V_D, indicating the potential difference between the source (S) and drain (D). A negative V_SD, such as -5V, signifies that the drain is at a lower potential than the source by 5 volts. Participants highlight the importance of consistent notation, noting that V_DS is more commonly used than V_SD in practice. The conversation also touches on the behavior of N-channel and P-channel MOSFETs, where V_DS is typically positive for N-channel and negative for P-channel devices. Overall, the thread emphasizes the significance of understanding voltage references in electronic components.
mzh
Dear Physics Forum users
Is it true that conventionally, V_{SD} is defined as the difference in potential between the drain and the source. Meaning, V_{SD} = V_S - V_D with the voltage on the source as the reference.
As an example: if V_{SD} is given as -5V (note minus), then this means the drain is at a potential of 5 Volts lower than the source. Right?
Thanks for hints.
To adhere to engineering conventions, VSD is the voltage of point S with reference to point D,
i.e., VSD ≡ VS - VD
http://img441.imageshack.us/img441/3331/nooo1.gif
The difference V_{SD} = V_S - V_D reveals how many volts S is above D. Suppose S was at 6v and D was at 2v, VS - VD = +4, and you can see that's the voltage at S with reference to D.
Thanks for hints.
Thanks for asking. :wink:
Hi Oxy
Thanks for your outline. But please explain to me, why my statement is different from yours:
me: "If V_SD is given as -5V (note minus), then this means the drain is at a potential of 5 Volts lower than the source"
you: "V_SD=V_S − V_D reveals how many volts S is above D."
I mean, it's the same to ask how many meters Paris is above sea level or how many meters below Paris is the sea level. No?
I think you might be confusing yourself with multiple negatives here.
If VSD is -5v, then S is -5v with reference to D. So S has the lower potential, or, equivalently, you can say D is at the higher potential. So it is equivalent to saying D is +5v with reference to S.
yes, i think i see it now. If, conventionally and for example, V_{SD} = V_S - V_D = -5, then this means V_S < V_D, which is what you say.
It follows that VSD = –VDS
still i could not find this conventional definition explicitly nowhere.
Can anyone help me for preparing mcq of electronics??
GE Transistor Manual , General Electric Company, revised seventh edition 1969, pp 524 & 529:
VKJ Circuit voltage between terminals K and J .
K, k Unspecified (general) measurement electrode. Also degrees Kelvin.
J, j Reference electrode
https://www.amazon.com/dp/B000U3J62U/?tag=pfamazon01-20
the way i was taught is "Your meter's red lead goes to first letter, black lead to second letter".
But that was before autoranging digital meters, so we often had to swap our meter leads to get an upscale reading..
I could swear V_{DS}=V_D-V_S ! Say for a N channel MOSFET, the V_{DS} is always positive. For N FET, Drain is always higher than source. For P-Channel FET, Drain is always lower than the source, so you have V_{DS} is always negative.
for that N channel in a proper circuit:
red lead on Drain
black lead on Source
meter will show VDS positive;
and for a P channel in a proper circuit, VDS negative.
Hi gulu. For help with exam and homework questions go to the homework forum here: https://www.physicsforums.com/forumdisplay.php?f=152 Start a new thread, include details of one question that you are having difficulty with, and show a genuine attempt at answering it. Someone is sure to come by and help you. Guaranteed. :smile:
red lead on Drain
Exactly.
Except when it's not, e.g. when a NMOS is used as a synchronous rectifier. A MOSFET can conduct in either direction.
It's not unknown for an OP to ask a question different from that intended, or at least to be seeming to. If that's the situation here, then mzh should feel free to come back and ask again. :wink:
I am talking in general. I know you can even reverse the C and E of a BJT and it will work somewhat also.
Thanks for the feedback on my question.
No, getting the answer that in V_{SD}, the drain is considered the reference electrode, such that V_{SD} = V_S - V_D was most supportive.
This is the first time I heard of drain being used as reference voltage! BJT, MOSFET and JFET "usually" act as transconductance devices where the collector/drain is the output of the current source. Voltage is set by the load impedance and the power supply voltage. Control is usually done on V_{GS}.
I put "usually" because there are ways to use transistor in special ways, I am talking the general amplifier working in lineal situation. I know all about that you can even turn the FET around and use the source as drain and it'll still kind of work.
Ok, so is it V_{GS} = V_G - V_S? My question is really only about the notational convention. Otherwise, correct sign will always be random.
Yes.
Sign is not random. For NMOSFET, V_{DS} is "usually" positive. That is,. the Drain is higher than the Source. For PMOSFET, Drain is negative so V_{DS} is negative.
yungman said:
Yes.
but why then was it problematic for you to read V_{SD} = V_S - V_D? If V_SD = 5V, it means V_S is 5V higher than V_D.
Normally we call it V_{DS} not V_{SD}.
check out this figure (which was the reason for my post):
[URL=http://picturepush.com/public/8993278][PLAIN]http://www5.picturepush.com/photo/a/8993278/640/8993278.jpg[/URL][/PLAIN]
from
http://www.nature.com/nature/journal/v445/n7127/abs/nature05498.html
btw., can anyone tell me if it is permitted to post such a figure on the web?
First time I ever seen it like this, check out all the data sheets of MOSFET and textbooks, it's always V_{DS}.
