How is the Coriolis generalized potential obtained
1 reply · 3K views · last reply
AlephClo
The Coriolis potential last term of (42) is obtained by integration through r and R from last term of (40).
I do not understand why we do not need to integrate through v as well, since the Coriolis force depends on v?
Diagram of a mass at (x, y) on a spring of length r attached to a rotating spring of length R, with angle theta = omega t from the x-axis; beside it, coordinate transformation equations x = R cos theta - r sin theta, y = R sin theta + r cos theta, and inverse R = x cos theta + y sin theta, r = -x sin theta + y cos theta.
Typeset page of physics equations (39) to (43) on the Lagrangian of a rotating two-spring system, including kinetic energy, rotating-frame force, generalized potential U and Lagrangian L.
Equation (41) is wrong I think, L must be replaced by U.
The forces for the 2 springs are F(r)= -kr, and F(R)= -kR (bold are vectors)
The generalized force Qj = Fi ⋅ δri/δqj (δ is del the partial derivative; j and i are indices)
the 4 terms of (42) are obtainable from the intergration relatively to r and R.
Since the Coriolis force is dependent of the velocity v, why we do not need to Integration relative to v = (dr/dt, dR/dt) as well?
Or more generally when is it required that we integrate through position and velocity the force that depends on position and velocity to obtain a generalized potential.
Thank you.
  • Diagram of a mass at (x, y) on a spring of length r attached to a rotating spring of length R, with angle theta = omega t from the x-axis; beside it, coordinate transformation equations x = R cos theta - r sin theta, y = R sin theta + r cos theta, and inverse R = x cos theta + y sin theta, r = -x sin theta + y cos theta.
  • Typeset page of physics equations (39) to (43) on the Lagrangian of a rotating two-spring system, including kinetic energy, rotating-frame force, generalized potential U and Lagrangian L.
The Coriolis force is a type of inertial force that depends on the velocity of the object. It is an effect of the Coriolis acceleration, which is caused by the rotation of the Earth. Therefore, there is no need to integrate through velocity for the Coriolis potential because it is already taken into account by the rotation of the Earth. However, if you were considering a different type of inertial force, such as a centrifugal force, then you would need to integrate both position and velocity in order to obtain the generalized potential.
