How Is the Initial Speed of a Projectile Calculated Using a Ballistic Pendulum?
The problem involves calculating the initial speed of a projectile using a ballistic pendulum. The setup includes a metal cage that traps the projectile, with specific masses and dimensions provided. The maximum angle reached by the pendulum after the projectile is fired is also given.
  • Participants discuss the application of conservation of angular momentum and energy, questioning the potential energy calculations and the height gained by the system. There are attempts to clarify the relationship between the pendulum's angle and the height change.
The discussion is ongoing, with participants exploring different interpretations of the height gained during the pendulum's swing. Some guidance has been offered regarding the geometric relationships involved, and there is a collaborative effort to clarify the calculations leading to the initial speed.
Participants express confusion regarding the correct application of trigonometric functions to determine height and the implications for energy conservation. There is a focus on ensuring that the correct projections are used in the calculations.
yesiammanu
A ballistic pendulum is a common device that is designed to measure the speed of small projectiles. As shown in the sketch on the right, it is composed of an initially stationary metal "cage" which traps the projectile and is suspended vertically by a very light weight rod attached to a low friction pivot. The bottom of the cage is usually equipped with a "pawl" (not shown) which prevents it from slipping backward after reaching it's maximum height. In a particular experiment, the projectile is a steel ball with a mass of 50.0 grams, the cage assembly has a mass of 250. grams, and the length L from the pivot to the center of mass of the entrapped ball + cage = 25.0 cm. After firing, the ball + cage reach a maximum angle from the vertical of 35.0. What was the initial speed 0o of the ball?
Conservation of Angular Momentum
L = r x p
L = Iw
I = MR2 for a thin cylindrical shell
w = v/r
1/2 Iw2 = mgh
L of ball = r x p = .25m * .05kg * v0 = .0125m * kg v0
L of ballistic pendulum + ball = Iw = (.3kg)(.25m)2w = .01875kg * m2w
.0125m * kg v0 = .01875kg * m2w
v0 = 1.5m * w
v0/1.5m = w
1/2 * MR2 * v02/2.25m2 = (.300kg)(9.8 m/s2)(.25m sin35)
1/2 * (.300kg)(.0625 m2)* v02/2.25m2 = .42 kg* m2/s2
.0041 kg v02 = .42 kg* m2/s2
v02 = 102.43 m2/s2
v0 = 10.1 m/s
The correct answer is 5.65, so I'm not sure where I messed up.
You applied the conservation of energy here, I believe? So, is the RHS of the equation really the potential energy gained?
Hint: Did the system go up by [tex]Rsin\theta?[/tex]
I would think it did, since the height changed and it ends up with 0 speed at 35 degrees
Did I need to factor in kinetic energy since it changes the x position? I thought it would be covered by angular
Umm, no.
Is the sin projection of the rod really the height gained? (No!) Also, check the cos projection...Is that the height either? What manipulation will give you the height gained by the system?
Hmmm.. I'm really confused
I tried to make a construction but I got even more confused
I thought that would just be Lsin35, since if sin was 90 degrees, you would be at exactly L
Please check attached image. That pink line is not equal to L, nor is the green angle equal to 350.
See the other attachment. What is the length of the blue line in terms of the given data?
hmmm...
cos theta = adj/hyp
hyp cos theta = adj
L cos 35 = adj for blue line
And then the red line would be L - Lcos35? so .25m - .25mcos35 = .045m?
yesiammanu said:
hmmm...
cos theta = adj/hyp
hyp cos theta = adj
You got it! :smile:
Replaced that in my equation and got 5.68, which is probably close enough. Thanks for help!
10K
