How is the Length of a Parallel Curve Calculated in Differential Geometry?
  • Context: Graduate
  • Thread starter Thread starter hypermonkey2
    Curve Length Parallel
The length of a parallel curve B to a closed convex plane curve A, defined by the equation B = A - rn, is calculated using the formula len(B) = len(A) + 2πr, where r is a positive constant and n is the normal vector. The derivation involves integrating the curvature of curve A, which contributes to the additional length of curve B. Specifically, the total contribution from the curvature integrates to 2π, reflecting the complete rotation of the tangent vector around the closed curve. This relationship holds true for convex curves, which maintain non-negative curvature.
  • Understanding of differential geometry concepts, particularly curves and surfaces.
  • Familiarity with curvature and its implications on curve length.
  • Knowledge of parameterization techniques for curves.
  • Basic principles of integration in the context of geometry.
  • Study the properties of convex curves and their curvature in differential geometry.
  • Explore the Gauss map and its applications in mapping curves to the unit sphere.
  • Learn about the relationship between curvature and arc length in parametrized curves.
  • Investigate the implications of the change of variables formula in integrals related to curves.
Mathematicians, students of differential geometry, and anyone interested in the geometric properties of curves and their lengths.
hypermonkey2
Hi,
I found this problem in Do Carmos "differential geometry of curves and surfaces".
it asks to show that the length of a parallel curve B to A given by:
B=A-rn
where r is a positive constant, and n is the normal vector, and A is a closed convex plane curve, positively oriented.
is given by
len(B)=len(A)+2*pi*r
The obvious start would be to integrate both sides under a standard parametrization or the curves, but why is it true that integrating rn will give 2*pi*n exactly?
any insight is appreciated.
Thanks!
I think I know one way of thinking about it, which can probably be made more rigorous if you want. Just to make it easier to think, consider a uniform grid defined on the closed curve B. Think of B as a deformed circle, so if you follow it with a tangent vector, the tangent vector will have rotated through an angle 2*pi after one going through the whole curve once.
Assume that curve A is "outside" B at a distance r. So curve B will turn out as the longest. This can be accurately defined by specifying that if the tangent vector mentioned above rotates to the left, then the defined A by choosing n at an angle pi/2 to the right of the tangent vector.
Transport the grid over to A using the normal vectors.
Consider one of the sections along curve B, the "inner" curve, e.g. between two division defined by the parametrization. It has some length dl. If the curvature of B is positive (like a circle), the corresponding length element of the "outer" curve A will be a bit longer. By how much? Well, by r*dphi, where dphi is a small angle.
Since we are going around the closed curve once, we must add all these dphi contributions along the curve. Somce will be positive, and some negative. In the end, the total must be 2*pi since we are going around once. Each contribution as r*dphi, so the total is 2*pi*r. They must add up to this, because the same angles define the rotation of the tangent vector to B, and it returns to its starting position after one travel around.
If the curve goes m times around (rotation of tangent vector), the result will be m*2*pi*r.
Torquil
hypermonkey2 said:
Hi,
B=A-rn
Thanks!
I hope this helps.
Parameterize A by arc length. Then B'(s) = A'(s) -rn'(s) = A'(s)(1 + rk(s)) where k(s) is the curvature.
|B'(s)| =(1 + rk(s)) |A'(s)| = 1 + rk(s)
BTW: I think a convex curve will always have non-negative curvature.
So the length of B is the length of A plus r times the integral of the curvature over the parameter interval.
The Gauss map of the curve takes the curve into the unit sphere by mapping each point on the curve to its unit normal translated to the origin. The derivative is just the curvature (I may be off by a sign here) times the unit tangent to the sphere. So the integral of the curvature is the integral of the pull back of dtheta to the curve, A. By the change of variables formula this is the integral of dtheta over the circle times the degree of the mapping and so is a multiple of 2 pi. For a convex plane curve I think the degree is plus or minus 1.
wicked!
I get it now,
thanks everyone!
cheers
  • · Replies 30 ·
