How is V1 deduced to be zero in the last step here?
The discussion centers on the analysis of a perfectly elastic collision between two billiard balls, where one ball is initially at rest. The key conclusion is that during the collision, the velocities of the two balls are exchanged, leading to the deduction that V1 must equal zero for the stationary ball after the collision. The equations used include momentum conservation and kinetic energy conservation, specifically the relationships 2V1V2 = 0 and v^2 = (v1 + v2)^2, which illustrate that one of the velocities must be zero post-collision.
  • Understanding of elastic collisions in physics
  • Familiarity with momentum conservation principles
  • Knowledge of kinetic energy equations
  • Basic algebraic manipulation skills
  • Study the principles of elastic and inelastic collisions in detail
  • Learn about momentum conservation in multi-body collisions
  • Explore Newton's laws of motion, particularly the third law
  • Investigate the mathematical implications of conservation laws in physics
Students studying physics, particularly those focusing on mechanics, educators teaching collision theory, and anyone interested in the mathematical foundations of physical laws.
califauna
A billiard ball moving at 2 m/s collides (0 degrees) with another of the same weight and at rest, in a perfectly elastic collision. Demonstrate with equations why the balls trade velocities.
In the provided explanation, I can understand what the parallel equations they set up represent, and how they reduce them by cancelling, but I can't see how the final logical step is made, where they deduce that V1 = 0,
What does the lower (momentum) equation tell you about v2?
Plug v=v1+v2 into v2=v12+v22 and you will get 2v1v2 = 0. So either v1 =0 or v2 = 0
That v^2 = (v1+v2)^2
When I do (v1+v2)2=v12+v22, after taking the root on both sides I get get v1+v2=v1+v2. What am I doing wrong?
You cannot take the square root of the right hand side like that. The square root of a sum is not the same as the sum of the square roots.
Instead, expand the left hand side.
Ah yes. Ok, I am left with 2V1v2 = 0.
Obviously the struck ball is going to be moving so it cannot be the one which ends up with a velocity of zero, but is there any other logical or mathematical method of deducting which of the two balls will be the one which will have zero velocity? Something which the exam question might require demonstation of in order to get the full marks for the question?
Both momentum and energy would be conserved if the first ball manages to pass straight through the stationary ball, but some other law may violated, do you think?
Not sure if the glitch in the matrix type clue about the balls passing through each other is a hint at this particlar law, but, Newtons third law regarding equal and opposite force?
Yes, you could look at it that way, but I was thnking more in terms of everyday experience that solid objects cannot pass through each other. Quantum effects aside.
