How is V1 deduced to be zero in the last step here?
In a perfectly elastic collision, a moving billiard ball collides with a stationary ball, resulting in a trade of velocities. The equations derived from conservation of momentum and kinetic energy lead to the conclusion that either V1 or V2 must equal zero. The discussion highlights the importance of correctly expanding equations rather than misapplying square roots. It is emphasized that the struck ball cannot have zero velocity, suggesting that the moving ball must come to rest after the collision. The conversation also touches on the implications of Newton's third law and the physical impossibility of solid objects passing through each other.
califauna
A billiard ball moving at 2 m/s collides (0 degrees) with another of the same weight and at rest, in a perfectly elastic collision. Demonstrate with equations why the balls trade velocities.
In the provided explanation, I can understand what the parallel equations they set up represent, and how they reduce them by cancelling, but I can't see how the final logical step is made, where they deduce that V1 = 0,
What does the lower (momentum) equation tell you about v2?
Plug v=v1+v2 into v2=v12+v22 and you will get 2v1v2 = 0. So either v1 =0 or v2 = 0
That v^2 = (v1+v2)^2
When I do (v1+v2)2=v12+v22, after taking the root on both sides I get get v1+v2=v1+v2. What am I doing wrong?
You cannot take the square root of the right hand side like that. The square root of a sum is not the same as the sum of the square roots.
Instead, expand the left hand side.
Ah yes. Ok, I am left with 2V1v2 = 0.
Obviously the struck ball is going to be moving so it cannot be the one which ends up with a velocity of zero, but is there any other logical or mathematical method of deducting which of the two balls will be the one which will have zero velocity? Something which the exam question might require demonstation of in order to get the full marks for the question?
Both momentum and energy would be conserved if the first ball manages to pass straight through the stationary ball, but some other law may violated, do you think?
Likes FactChecker and califauna
Not sure if the glitch in the matrix type clue about the balls passing through each other is a hint at this particlar law, but, Newtons third law regarding equal and opposite force?
Yes, you could look at it that way, but I was thnking more in terms of everyday experience that solid objects cannot pass through each other. Quantum effects aside.
Likes califauna
