How Is Work Calculated in Gravitational Fields?
2 replies · 28K views
3.141592654
Newton's Law of Gravitation states that two bodies with masses m1 and m2 attract each other with a force:
[tex]F=\frac{Gm_{1}m_{2}}{r^2}[/tex]
where r is the distance between the bodies and G is the gravitational constant. If one of the bodies is fixed, find the work needed to move the other from r=a to r=b.
[tex]W=F*x[/tex]
[tex]x=r[/tex]
[tex]W=\frac{Gm_{1}m_{2}}{r^2}r = \frac{Gm_{1}m_{2}}{r}[/tex]
[tex]r=b-a[/tex]
[tex]W=Gm_{1}m_{2}(\frac{1}{b-a})[/tex]
The answer states that [tex]W=Gm_{1}m_{2}(\frac{1}{a}-\frac{1}{b})[/tex]. Did I make a mistake in setting up the problem?
Two bodies are attracting each other. If you want to take on body away from the other, then the displacement and the force are in the opposite direction.
So W = F*x*cos(theta). Here what is theta?
It seems that you have not learned calculus
The force here is not a constant,so you can't just use W=F*x
