How long does it take it increase speed?
  • Thread starter Thread starter RanHam335
    increase Speed
To determine how long it takes for a freight train with a mass of 1.2e+7 kg to accelerate from rest to 82 km/h under a constant pull of 8.4e+5 N, the relevant formula is t = (mass * velocity) / force. After converting 82 km/h to m/s, the calculation yields a time of approximately 5.1e-2 minutes. However, some participants question whether this duration is realistic for such a large train to reach that speed. The discussion emphasizes the importance of correctly applying the physics formulas and unit conversions. Overall, the calculations and assumptions surrounding the time required for acceleration are critically analyzed.
RanHam335
A freight train has a mass of 1.2e+7 kg. If the locomotive can exert a constant pull of 8.4e+5 N, how long does it take to increase the speed of the train from rest to 82 km/h?
(mass*velocity)/time=force
(1.2e+7 * 82)/h = 8.4e+5
i solved for h
h = (8.4e+5)/(9.84e+8)
h = 8.54e-4
then i had to convert from hours to min.
8.54e-4*60
so i got
5.1e-2 min
this is my first time posting on this forum so i hope i followed the right format.
82km/h = \frac{82*1000m}{3600s}
can you explain the above?
I just converted the speed from km/h to m/s which is usually what you should do.
82km/h
in 1h train travels 82km
=> in 1h train travels 82*1000m
in 3600s train travels 82000m
in 1s train travels 82000/3600 m
therefore the velocity in m/s is 820/36
that doesn't answer my question, i think I am messing up on the formula. I have one submission left so i don't want to risk it
F=\frac{mv}{t} \Rightarrow t=\frac{mv}{F}
t=\frac{(1.2*10^7 kg)*((\frac{82000}{3600} ms^-1)}{8.4*10^5 N}
Can you calculate now?
But your answer was 5.1*10^{-2}minutes. Doesn't that seem like a small amount of time to go from 0 to 82km/h ?
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 21 ·
