How long does it take the giraffe to weigh 85 kg?
  • Thread starter Thread starter Paulo2014
The discussion focuses on solving the quadratic equation for the weight of a giraffe, represented by W=(t^2)/4-t+68, to determine the time it takes to reach 85 kg. Participants clarify that the equation must be rearranged to t^2-4t-68=0 to apply the quadratic formula or complete the square method. The correct solution yields t ≈ 10.5 months, as negative time values are extraneous. The conversation emphasizes the importance of understanding quadratic equations and methods for solving them.
  • Understanding of quadratic equations
  • Familiarity with the quadratic formula
  • Knowledge of completing the square method
  • Basic algebraic manipulation skills
  • Study the quadratic formula in detail
  • Practice completing the square with various equations
  • Explore applications of quadratic equations in real-world scenarios
  • Learn LaTeX for better mathematical expression formatting
Students studying algebra, educators teaching quadratic equations, and anyone interested in mathematical problem-solving techniques.
Paulo2014
The weight, W kg, of a giraffe over its first two years of life, is given by the equation
W=(t^2)/4-t+68
where t is the time in months since the giraffe was born.
I know i need to rearage the equation but i can't remember how so any help is appreciated...
Which letter represents the weight? Put 85 there and solve it.
Yeah I understand that but how would I solve it?
its the (t^2)/4 bit i don't understand how to solve...
Let me see if this is the thing you have:
\frac{t^2}{4}-t+68=85
That's a quadratic equation. Before you can solve, what does the equation have to look like?
Then, since fractions give me a headache, like like to ditch them. Can you think of a method of getting rid of them?
multiply 4 to both sides?
Yes please.
So it would be:
t^2-t+68=340?
so you have:
4(\frac{t^2}{4}-t+68=85)
make sure that you are careful about your distributive property.
EVERYTHING gets multiplied by 4.
but doesn't the t^2 already have the /4 so wouldn't it be:
t^2+4(-t+68=85)?
yes
t^2-(4)t+(4)68=(4)85
then what?
expand.
So it is t^2-4t+272=340
Is that right?
yes.
In order to solve ANY equation, what does it have to be set equal to?
There's ONE MORE STEP before you can solve it.
I can't remember... :(
Look for an example in your book.
It has to be in the form ax=b
thats what my textbook says... is that what you meant?
You are looking for the ZEROS
What would you set the equation equal to to get the ZEROS?
i'm lost...
In order to solve any equation, it must be set equal to ZERO!
HOORAY!
How do you manipulate your equation to get it equal to zero?
I see. take 340 from both sides so the equation is:t^2-4t-68=0 is that correct?
Sit down and read the chapter ... do every single example problem! It will serve you better than trying to solve this problem.
rocomath is right.
and you did get the equation right. If you aren't sure how to solve it, you DO need to read the chapter.
I use the quadratic formula don't I...
yes you do
I got x=10.48528137423857 or -6.4852813742385695
Is that right?
t has to equal 10.5 as you can't have a negative amount of years right?
Yes, the negative answer is extraneous.
No, that's not what he is talking about.
happyg1, you don't have to set an expression to 0 to solve an equation. Here, of course, you could subtract 340 from both sides to get x2- 4t- 68= 0 and try to factor. However, I don't think it will be so easy to factor this.
My favored way of solving x2-4t+ 272=340 would be to subtract 272 from both sides: x2- 4t= 68 and then complete the square.
So is my answer incorrect?
  • · Replies 18 ·
