How long will it take to mow a football field?
  • Thread starter Thread starter BuhRock
    Field
Estimating the time required to mow a football field measuring 91.44 meters by 48.8 meters with a standard home lawn mower moving at 1 km/h and a cutting width of 0.5 meters results in a total mowing time of approximately 10 hours. The calculation involves determining the area of the field, dividing it by the mower's width, and accounting for the number of passes needed, which totals 98. Additional time for turning and breaks can be included for a more realistic estimate, but some participants suggest neglecting these factors for simplicity.
  • Understanding of area calculation in square meters
  • Knowledge of unit conversion from feet to meters
  • Familiarity with basic speed and time calculations
  • Awareness of lawn mower specifications, including cutting width and speed
  • Research the formula for calculating the area of a rectangle
  • Learn about unit conversion techniques between imperial and metric systems
  • Explore the impact of mower speed on efficiency and time management
  • Investigate best practices for mowing large areas to optimize time and effort
This discussion is beneficial for landscapers, lawn care professionals, and anyone involved in planning or executing large-scale mowing tasks, as well as those interested in optimizing time management in outdoor maintenance activities.
BuhRock
1. Estimate how long it would take one person to mow a football field using an ordinary home lawn mower. Assume the mower moves at 1 km/h and has a .5m width.
2. Are we using a football field with dimensions of 300ft by 160 ft?
Will I need to find the area of the field in m^2?
3. I converted ft into meters so I have the length of the field to be 91.44 meters and the width is 48.8 meters. After this part, I'm not sure what to do. Would you get the area and then divide by .5?
OK. You made a first step - converting units to metric...
You are almost right, saying that you should divide area by the mowing width. You forgot to divide it also by mower speed to obtain the total time.
If you want to be more precise, you should notice, that the last pass of the mower won't be fully efficient. If you go with your mower along the field, then you need not 97.6, but 98 passes. Even if you mow only half of mower width, you still walkk with the same speed.
Each pass takes 91.55m/(1km/h) = 0.09155 hour. Plus some time you need to turn - 5s maybe? So the total time is 98*0.09155h + 97*5s = 9.46h. To be not too precise: 9.5h is the first estimate. Add a half hour for two short breaks (the worker may not eat for the whole day, but should be allowed to [Obscenity removed] at least...) - you have 10 hours.
Where did the 98 come from?
98?
Width of the field is 48.8m. And in one pass you make 0.5m
Although this may come a little late, xts' response is incorrect. You are given no information regarding the turning of the mower, nor worker breaks, you should therefore neglect any break times or the time required to turn the mower.
  • · Replies 21 ·
9K
13K
9K
