How many BTU/hr needed to cool 500 CFM of air 100F degrees?
To cool 500 CFM of air by 100°F, approximately 1.08 BTU/hr is required per degree of cooling, resulting in a total cooling requirement of 108 BTU/hr. The cooling efficiency is slightly temperature dependent; for instance, at 500°F, the required BTU/hr increases by about 5% compared to lower temperatures. For precise calculations, users should refer to specific heat tables or equations that account for varying temperatures.
  • Understanding of BTU (British Thermal Unit) calculations
  • Familiarity with CFM (Cubic Feet per Minute) airflow measurements
  • Knowledge of specific heat and its temperature dependency
  • Ability to interpret thermodynamic tables and equations
  • Research specific heat tables for various temperatures
  • Learn about thermodynamic principles related to cooling systems
  • Explore HVAC design calculations for airflow and cooling requirements
  • Investigate temperature-dependent cooling efficiency in HVAC systems
HVAC engineers, mechanical engineers, and anyone involved in designing or optimizing cooling systems for air handling applications.
matt621
And does it matter if you are going from 200F to 100F or 500F to 400F? ie, is it temperature dependent?Thanks
It takes approximately 1.08 BTU/hr to cool a CFM by 1 degree, so I'll let you calculate that. :wink:
For the second part, no, it isn't quite constat over large temperature differences. At 500F, it is only about 5% larger. You can google for tables and/or equations for specific heat at various temperatures.
14K
