How many independent components does a tensor have?
18 replies · 3K views · last reply
MatinSAR
How many independent component does a tensor have?
Tensor analysis.
Text on a white background stating the symmetry relations of the Riemann-Christoffel curvature tensor R_iklm, the antisymmetry in the last two and first two indices, and asking to show the independent components drop from 256 to 36.
It's a 4th-dimensional 4th-rank tensor so at first we have ##4^4=256## components.
According to the book, Given that ##R_{iklm}=-R_{ikml}## 256 components reduces to 96. But I cannot see how.
For one pair of i,k 16 components are dependent. We have 12 pairs of i,k(for ##i≠k## becsuse for i=k tensor's components should be 0) so 256 should reduces to ##256-12*16=4*16=64##.Thanks for your help ...
We have 16 independent combinations of ##i,k##. For each such combination, we have an antisymmetric tensor ##R_{..lm}=-R_{..ml}##. ... That gives us ##96## components.
only six pairs: 01 02 03 12 13 23
A better idea just came in to my mind:
For ##m=l## we have ##R_{ikmm}=0## so ##4^3=64## compenents should be zero. Therefor we have 192 independent components. If I divide this 192 by 2 I'll get the right answer.
For ##m≠l## we have ##R_{iklm}=-R_{ikml}## but how it imply that 192 should be divivded by 2?
The problem is that I cannot see why.
Did you remove duplicate combinations? (like 3 2)
The antisymmetric tensor has 6 independent components. That is, 6 for each one of 16 combinations of ##i,k##. Total: ##16 \times 6=96##.
That's what independent means: if 32 = -23 there is only one independent component, not two. So only 01, 02, 03, 12, 13 & 23 are independent (and 00, 11, 22, 33 all vanish), so 6 independent components total.
This is true only for 4th-dimensional 4th-rank tensor? Or every tensor?
What a bout symmetric tensor? Does it have 6 independent components?
4-dimensional, rank 2.
No. You can make a list or draw a matrix, and count.
My count was for an antisymmetric rank-2 tensor in 4 dimensions (for your example, the symmetries of the rank-4 Riemann tensor behave like the product of two independent antisymmetric rank-2 tensors, hence 6 x 6 = 36 independent components total). A symmetric rank-2 tensor in 4-dimensions has 10 components: 00, 01, 02, 03, 11, 12, 13, 22, 23, 33. In other dimensions the counts are different.
For an NxN matrix, the number of independent elements is
general: ##N^2##
symmetric: ##\frac 12N(N+1)##
antisymmetric: ##\frac 12N(N-1)##
Thank you to everyone ... I've understand the first step.
We have 256 components. For ##R_{iklm}## we know there are 16 combinations of i and k and there are 16 combinations of m and l.
Using equation ##R_{iklm}=-R_{ikml}## we know there are 10 dependent components. So we have ##256 - 16(10) = 96## independent components.
Now using next equation ##R_{iklm}=-R_{kilm}## again there are 96 independent components. But how can I find out How many of these 96 independent components also apply to the previous condition and are now repeated?
At first we have 256 independent components, using ##R_{iklm}=-R_{ikml}## 256 reduces to 96.
Then using ##R_{iklm}=-R_{kilm} ## 96 reduces to 36. Am I right?
MatinSAR said:
We have 256 components. For ##R_{iklm}## we know there are 16 combinations of i and k and there are 16 combinations of m and l and.
Consider the rank-4 product ##P_{iklm}=A_{ik}B_{lm}## of two arbitrary rank-2 tensors ##A_{ik}## and ##B_{lm}##. Each tensor ##A## and ##B## has in general ##16## components, so the product ##P## starts with ##16\times 16=256## distinct components. Now impose the two independent antisymmetries:$$P_{iklm}=-P_{kilm}\Rightarrow A_{ik}B_{lm}=-A_{ki}B_{lm}\Rightarrow A\text{ has 6 components}$$$$P_{iklm}=-P_{ikml}\Rightarrow A_{ik}B_{lm}=-A_{ik}B_{ml}\Rightarrow B\text{ has 6 components}$$So the two antisymmetries together give ##P=A\times B## a total of ##6\times 6=36## independent components. The same argument applies to ##R_{iklm}##.
This method is different from what my proffessor told us ...
And it is easier. Thank you.
Problem is solved. Thank You, Everyone!
Hello. I've thought about your suggested method. What I've understand is that because of ##P_{iklm}=-P_{kilm}\Rightarrow A_{ik}B_{lm}=-A_{ki}B_{lm}## A can only have 6 independent components but components of B are unaffected. So till now we have 16*6=96 independent components.
After applying ##P_{iklm}=-P_{ikml}\Rightarrow A_{ik}B_{lm}=-A_{ik}B_{ml}## Which does not affect A But affects B, B can have only 6 independent components. Applying both gives us a 6*6 matrix with 36 independet components. Am I right?!
