How many real and non-real roots?
  • Context: MHB
  • Thread starter Thread starter SweatingBear
    Roots
The discussion revolves around determining the number of real and non-real roots for the equations $$z^5 = 32$$ and $$z^9 = -4$$. Participants explore various mathematical approaches, including trigonometric identities and Descartes' rule of signs, to analyze the roots of these polynomial equations.
  • Exploratory, Technical explanation, Debate/contested, Mathematical reasoning
  • One participant calculates the roots of $$z^5 = 32$$ using polar coordinates and concludes there is one real root and four non-real roots.
  • Another participant suggests an alternative approach for $$z^9 = -4$$, proposing to let $$r = -\sqrt[9]{4}$$ and derive the roots similarly, but questions the initial setup of the argument.
  • Descartes' rule of signs is cited by some participants, indicating that $$z^5 - 32$$ has one positive root and zero negative roots, leading to the conclusion of one real root for this equation.
  • For $$z^9 + 4$$, Descartes' rule suggests zero positive and one negative real root, again indicating exactly one real root.
  • Participants discuss the handling of the negative sign in the second equation, with suggestions on how to represent it using trigonometric identities.
  • One participant emphasizes that since both equations have odd exponents, they will each have only one real root, leading to the conclusion that the first equation has four complex roots and the second has eight complex roots.
  • A general statement about the conditions for real roots based on the parity of the exponent is proposed, noting that if $$n$$ is odd, the only real solution occurs at a specific value.
Participants generally agree that both equations have one real root, but there are multiple competing views on the methods used to arrive at this conclusion and the handling of complex roots. The discussion remains unresolved regarding the specific details of the approaches and the implications of the results.
Some participants express uncertainty about the application of trigonometric identities and the implications of using Descartes' rule of signs. There are also unresolved questions about the handling of negative values in the context of the equations.
SweatingBear
How many real and non-real roots does $$z^5 = 32$$ have? $$z^9 = -4$$?
For $$z^5 = 32$$: $$z^5 = r^5 ( \cos 5v + i \sin 5v )$$ and $$32 = 32 ( \cos 0 + i \sin 0 )$$ yields
$$r = 2 \\ 5v = n \cdot 2\pi \iff v = n \cdot \dfrac {2\pi}5$$
So all roots are given by
$$z = 2 \left( \cos \left( n \cdot \frac {2\pi}5 \right) + i \sin \left( n \cdot \frac {2\pi}5 \right) \right)$$
where $$0 \leqslant n \leqslant 4, \ n \in \mathbb{Z}$$. Let us rule out all real roots by letting the imaginary part equal zero.
$$\sin \left( n \cdot \frac {2\pi}5 \right) = 0 \iff n \cdot \frac {2\pi}5 = k \cdot \pi \iff n = \frac {5k}2 $$
In order for $$n$$ to be an integer, $$2$$ must divide $$k$$. Thus $$k = 2p$$ where $$p \in \mathbb{Z}$$ and consequently $$n = 5p$$. With $$0 \leqslant n \leqslant 4$$ we have
$$0 \leqslant 5p \leqslant 4 \iff 0 \leqslant p \leqslant 0.8 \implies p \in \{ 0 \}$$
So there is one real root and the remaining four are non-real. Similar arguments for $$z^9 = -4$$ yield
$$9v = \pi + n \cdot 2\pi \iff v = \frac {\pi}9 + n \cdot \frac {2\pi}9$$
Equating the imaginary part to zero yields
$$\frac {\pi}9 + n \cdot \frac {2\pi}9 = k \cdot \pi \iff n = \frac {9k-1}2$$
$$2$$ must divide $$9k-1$$ so $$9k-1 = 2p$$. Using $$0 \leqslant n \leqslant 8$$ however yields $$0 \leqslant p \leqslant 8$$. The equation does not have $$9$$ real solutions, so what went wrong?
I don't know if it would solve your problem or not, but in the second problem, couldn't you let $r=-\sqrt[9]{4}$, and then use $9v=n\cdot 2\pi$, more like before? Then $n=9k/2$, so $k=2p$, and hence $n=9p$. So $0\le n\le 8$ forces $0\le 9p\le 8$, and you must have $p=0$, as before.
Descartes rule of signs says $$z^5-32$$ has 1 positive root and 0 negative roots, hence has exactly one real root.
For $$z^9+4$$ Descartes tell us it has zero positive and one negative real root, so again has exactly one real root.
How did you end up with $9v = n \cdot 2 \pi$? $9v$ must equal the argument of the number in the right-hand side i.e. $\pi + n \cdot 2\pi$, I see no other way.
Excellent! Thanks for that perspective, however I will not rest until I have figured out the nitty and gritty details of my approach. Thanks again.
You can take care of the minus sign in two ways; one is through the arguments to your trig functions, and the other is in the overall multiplier. So, if you say that
$$z^{9}=- 4 \left[ \cos ( 2 \pi n )+i \sin ( 2\pi n) \right],$$
I think you'll find that equivalent to
$$z^{9}= 4 \left[ \cos ( \pi+ 2 \pi n)+i \sin ( \pi+ 2\pi n) \right].$$
The first approach is much more analogous to what you did before, and might therefore be more useful.
Oh right of course, the trigonometric identities! But here is a follow-up question: How would the issue be resolve if it was the case that we could not take advantage of a trigonometric identity?
Much appreciated you could share your thoughts, Ackbach.
If you are only interested in the NUMBER of roots and not the values of each root then there is a simple answer. Since both exponents are ODD , both equations will have only one real root. That means the first equation must have 4 complex roots , all distinct , the second equation must have 8 complex roots, all distinct. Here is why...
For real number a and positive integer n , $z^n = a$ has n dstinct roots symmetrically placed on the circle centered at the origin of the complex plane with radius $ | \sqrt[n]{a} | $. There are only 2 places on this circle where you can get real roots , $ (|\sqrt[n]{a }| , 0) $ and $ (- |\sqrt[n]{a }| , 0) $ That's it. If n is ODD then you hit exactly one of these two places , if n is even you hit both of them if a is positive or none of them if a is negative.
Suppose that $$z^n = r $$ where $$n\in \mathbb{Z}^+, \, r\in \mathbb{R}^+$$
Then we can rewrite as follows
$$\Large {z = \sqrt[n]{r}e^{\frac{2\pi k}{n}\, i }}\,\,\, 0\leq k< n$$
Then look for the solutions of the equation
$$\sin \left( \frac{2\pi k}{n} \right) = 0 $$ to find real roots .
we know that the sin has zeros for $m \pi \,\,\, , m\in \mathbb{Z}$ so we have
$$2k = m \, n $$ . So we conclude that if $n$ is odd , the only real solution occurs at $k=0$ , because $k< n $, hence $z = \sqrt[n]{r}$.
Try to make a general statement for $r$ is arbitrary real.
