How many revolutions does the merry go round make as it stops?
  • Thread starter Thread starter mags
    Revolutions
A 5.0m diameter merry-go-round with a 4.0s period slows to a stop in 20 seconds. The initial linear speed is calculated as 3.9 m/s, leading to an initial angular speed of 1.56 rad/s. To find the total number of revolutions as it stops, one must consider the average speed during deceleration, which is half of the initial speed. The correct calculation reveals that the merry-go-round makes 24.8 revolutions before coming to a complete stop. The problem highlights the importance of using average speed in rotational motion calculations.
mags
A 5.0m diameter merry go round is initially turning with a 4.0s period. It slows down and stops in 20 s. How many revolutions does the merry go round make as it stops?
w=v/r
v=2(pi)r/T
v=2(pi)2.5/4
=3.9 m/s
w=v/r
= 3.9/2.5
=1.56 rad/s
1.56 rad/s X (1rev/2(pi)rad)=2.48 rev
how is the answer 24.8? I don't understand...Please help
mags said:
v=2(pi)2.5/4
=3.9 m/s
w=v/r
= 3.9/2.5
=1.56 rad/s
This is the initial angular speed. The final angular speed is zero. What's the average speed as it slows down?
(Note that ω = 2π/T.)
i don't understand...
Final velocity (linear and angular) is zero because the problem says the merry-go-round stops. Try thinking of this in terms of linear kinematics, making the appropriate substitutions.
mags said:
w=v/r
= 3.9/2.5
=1.56 rad/s
You found the initial angular speed ω. Good.
What you did here was to convert from rad/s to revolutions per second; so that should be 2.48 rev/s.
To get the number of revolutions, you need to compute the angle traveled by the merry go round as it comes to rest. That's just the rotational analog to Distance = speed X time. Since the speed is not constant, you must use the average speed, not the initial speed. (The average speed is just half the initial speed.)
thanks a bunch...solved it!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
