How many times can we differentiate this function?
21 replies · 6K views · last reply
transgalactic
how many times can we differentiate this function??
how many times can we differentiate this splitted function on point x=0
[itex] f(x) = \{ x^{2n} \sin (\frac{1}{x}) <br /> ,x \ne 0 [/itex]
[itex] \{ 0,x = 0}} \\ <br /> [/itex]
Hint: for what values of n can we differentiate it once? :smile:
we can differentiate every function enless times
for example
f(x)=x^3
f'(x)=x^2
f''(x)=x^1
f'''(x)=1
f''''(x)=0
f'''''(x)=0
etc..
really?
how many times can we differentiate this function at x=0?
[itex] f(x)\ =\ x^2\sin (\frac{1}{x}) <br /> ,x \ne 0<br /> <br /> <br /> [/itex]
{ 0,x = 0​
what now?
[tex] f(x)\; = \;x^2 \sin ({1 \over x}),x \ne 0[/tex]
[tex] f'(0) = \mathop {\lim }\limits_{x \to 0} {{x^2 \sin ({1 \over x}) - 0} \over {x - 0}} = 0 [/tex]
transgalactic said:
what now?
uhh? :confused:
use the product rule …
f'(x) = … ?​
transgalactic said:
what now?
Yes, that's correct. But tiny-tim's point, I think, is that the derivative for for x not 0 (which he didn't actually ask) is 2x sin(1/x)- cos(1/x) so f '(x) is not continuous at x= 0 and so does not have a second derivative there.
It is NOT true that "we can differentiate every function enless times" though that is certainly true for polynomials.
A simpler example is
[itex]f(x)= (1/2)x^2[/itex] if [itex]x\ge 0[/itex]
[itex]f(x)=-(1/2)X^2[/itex] if x< 0
Then f'(x)= x if [itex]s\ge 0[/itex] and f'(x)= -x if x< 0: in other words f'(x)= |x| and that is not differentiable at x= 0.
I got that example, of course, by integrating |x|. Integrate again, to get
[itex]f(x)= (1/6)x^3[/itex] if [itex]x\ge 0[/itex]
[itex]f(x)= -(1/6)x^3[/itex] if x< 0
and you get f having first and second deriviatives but not a third derivative. You can use that to get example of functions that are differentiable n times but not n+1 times for any integer n.
i assumed that in the case of prooving the second derivative point x=0 the function turns to 0 too.
[tex] f(x) = \ x^{2n} \sin (\frac{1}{x})[/tex]
[tex] f'(x)=2nx^{2n-1}\sin (\frac{1}{x})-x^{2n}\frac{1}{x^2}\cos(\frac{1}{x})[/tex]
[tex] f''(x)=\lim_{x->0+}\frac{2nx^{2n-1}\sin (\frac{1}{x})-x^{2n}\frac{1}{x^2}\cos(\frac{1}{x})-0}{x-0}=\\<br /> [/tex]
[tex] f''(x)=\lim_{x->0+}\frac{2nx^{2n-2}\sin (\frac{1}{x})-x^{2n-1}\frac{1}{x^2}\cos(\frac{1}{x})-0}{1}[/tex]
so in the plus side i will get 0
and on the minus side
but i can't keep doing this derivatives till i get two different limits
there must be an easier way
transgalactic said:
… [tex] f''(x)=\lim_{x->0+}\frac{2nx^{2n-1}\sin (\frac{1}{x})-x^{2n}\frac{1}{x^2}\cos(\frac{1}{x})-0}{x-0}=\\<br /> [/tex]
Why are you using this lim notation?
Just use the product rule and chain rule, and then see whether the result converges to a limit as x -> 0.
In particular:
does sin(1/x) converge as x -> 0?
does cos(1/x) converge as x -> 0?
does xsin(1/x) converge as x -> 0?
does xcos(1/x) converge as x -> 0?​
sorry, no idea what you mean :confused:
here is the first derivative
[tex] f'(x)=2nx^{2n-1}\sin (\frac{1}{x})-x^{2n}\frac{1}{x^2}\cos(\frac{1}{x})[/tex]so i need to do limit for positive side of zero
equals limit of negative side of zero equals f(0)but its not a solutions
i can't keep doing derivatives
oh i see now …
you're talking about lim x -> 0+ and lim x -> 0-
it doesn't matter in this case …
either they both exist, or neither does.
[tex] f'(x)=2nx^{2n-1}\sin (\frac{1}{x})-x^{2n}\frac{1}{x^2}\cos(\frac{1}{x})[/tex] …
transgalactic, when someone at PF helps by asking you a question, answer it!
even if you can't see the point …
I'll ask again: does sin(1/x) converge as x -> 0?
no
the function is bounded and Non convergent
so is the cos (1/x)
but x*sin(1/x) and x*cos(1/x) are convergent because lim of 0*bounded =0
transgalactic said:
no
so is the cos (1/x)
That's right :smile: …
sin(1/x) and cos(1/x) oscillate between -1 and +1,
but xnsin(1/x) and xncos(1/x) oscillate between -xn and +xn, and so converge to 0, for n ≥ 1.
Maybe, but you don't need to calculate the full derivative (with the correct factors), you only need to know the powers of x that are involved. :wink:
how is that??
how the power of X can affect if the derivative converge or not
i don't know what you mean regarding the power things
can you explain that?
for n=0
we can't differentiate it
for n=1
we can differentiate it once
whats the general rule??
transgalactic said:
for n=0
for n=1
That's better! :biggrin:
Try it for n= 2 …
how many times does it work? …
when it stops working, what's the spanner-in-the-works stopping it? …
when does that happen for larger n? :wink:
it can go forever
for every n>0 i get 0*bounded
there is no limitation
[tex] f(x) = x^{4} \sin (\frac{1}{x})\\[/tex]
[tex] f'(x)=lim_{x->0}\frac{x^{4} \sin (\frac{1}{x})}{x}=lim_{x->0}{x^{3} \sin (\frac{1}{x})}=0[/tex]
transgalactic said:
it can go forever
uhh? none of that makes sense :confused:
try again, and write it out properly​
i was given this expression
[tex] \dfrac{\mathrm{d}^r}{\mathrm{d}x^r}\left(x^{2n}\sin\left(\frac{1}{x}\right)\right)<br /> &=\left((-1)^r x^{2(n-r)}+x^{2(n-r)+2}P_{n,r}(x)\right)\sin\left(\frac{1}{x}+r\frac{\pi}{2}\right)\\<br /> &\quad+x^{2(n-r)+1}Q_{n,r}(x)\sin\left(\frac{1}{x}+(r-1)\frac{\pi}{2}\right)<br /> \end{align*}[/tex]
is it in any use??
for n=2 it differentiates
[tex] f'(x)=lim_{x->0}\frac{x^{4} \sin (\frac{1}{x})-0}{x-0}=lim_{x->0}{x^{3} \sin (\frac{1}{x})}=0[/tex]
is it in any use??
did you get that from another forum? :rolleyes:
it may be right (i haven't checked it) …
but it's useless to you if you don't know how to get it, isn't it? :smile:​
uhh? still makes no sense …
you haven't even used the product rule
