How much heat can I get from the sun?
  • Thread starter Thread starter zzinfinity
    Heat Sun The sun
This discussion focuses on estimating the heat absorption through a south-facing window in Boulder, Colorado, during early April. Key factors include the intensity of sunlight, which averages around 1 kW/m², and the impact of variables such as window type, roof overhang, and the angle of sunlight. To calculate the heat absorbed, one must consider insolation, surface properties of the roof, roof wall properties, and air properties within the house. The conversation suggests using an air conditioning heat load program and statistical methods for more accurate results.
  • Understanding of insolation and its calculation
  • Knowledge of thermal properties of materials (absorptivity, reflectivity)
  • Familiarity with heat transfer principles (conduction, convection)
  • Basic skills in using heat load calculation software
  • Research how to calculate insolation for different latitudes
  • Learn about the thermal properties of various window types
  • Explore heat load calculation software options
  • Investigate statistical methods for estimating heat absorption
Students in architecture or engineering, homeowners interested in passive solar design, and professionals involved in energy efficiency projects.
zzinfinity
Hi,
I'm a student doing a project that involves building a model house with passive solar heating system. I'm curious if there is a way to approximate the amount of heat I will absorb through a south facing window on a sunny day, in early April. I realize this depends on many variables, but I'm just looking for a ball park figure (10 BTUs, a billion BTUs?)
I'm in Boulder Colorado (North Latitude 40 degrees). The average high is about 55F.
Anyone have any thoughts? Thanks!
zzinfinity said:
Hi,
Here's a start.
http://en.wikipedia.org/wiki/Insolation
A airconditioning heat load program would be great otherwise you have to get charts for your Latitude showing the radiation intensities on a south wall, Note the amount of window in direct sunlight is affected by the overhang of the roof (which you would have to calculate, yes for each hour) The radiation intensities would be given in per square meter so the final result depends on how many square meters the wall is assuming nothing shades it. You would have to do the calculation for each hour for the differing intensities and work out the heat for each hour (Watts multiplied by seconds (3600) If I remember right there is a certain amount reflected by the glass and some absorbed and lost back to outside. (I think it depends on what type of glass)
Bright sunlight has an intensity of roughly 1kW/m^2. Clouds (->weather data), other sources of shadows (->architecture) and surfaces not perpendicular to the sunlight (->architecture and latitude) will reduce this number for your house. In addition, the window will reflect some fraction of the sunlight (->glass properties).
For a ballpark figure, take a few hours of full sunlight and convert 1kW/m^2 to all sorts of strange unit systems if you like.
You need to know a few things:
1 - The relative angle of the sun and roof. This is insolation.
2 - The surface properties of the roof. Specifically the absorbtivity and reflectivity. This defines how the radiation behaves at the surface.
3 - The roof wall properties. This includes thickness and the conduction coefficient which defines how the heat propagates through the roof.
4 - Air properties of the house interior. This includes initial temperature and depending how complicated you want to get, conduction and convection coefficients.
You picked a complicated project. If this is for high school I recommend something simpler.
If possible use statistical methods.
36K
28K
