Melting Ice in Lemonade: Calculating Heat Transfer
  • Thread starter Thread starter kingdomxiii
    Ice Water
The discussion centers on calculating the amount of ice that melts when added to 1 kg of lemonade, which cools from 20°C to 0°C. The heat extracted from the lemonade is calculated to be 83.38 kJ, using the formula Q = mcΔT, where the specific heat capacity of water is 4.169 kJ/kg°C. The latent heat of fusion for water is established as 333 kJ/kg, leading to the conclusion that 0.25 kg of ice melts as a result of this heat transfer.
  • Understanding of heat transfer principles
  • Familiarity with the specific heat capacity of water
  • Knowledge of latent heat of fusion
  • Ability to apply the formula Q = mcΔT
  • Study the concept of latent heat in thermodynamics
  • Learn about phase changes and their energy requirements
  • Explore practical applications of heat transfer in real-world scenarios
  • Review problems involving heat transfer calculations in different states of matter
Students studying thermodynamics, physics enthusiasts, and anyone interested in understanding heat transfer and phase changes in materials.
kingdomxiii
Ice at 0°C is added to a 1 kg of lemonade cooling it from 20°C to 0°C. How much ice melts? (The heat capacity of lemonade equals that of water.)
Q = mcΔT
Found the heat in of the lemonade to the ice... = 83.38 kJ and don't know where to go from there. c of water is 4.169.
Q = mcΔT
What happens to the ice that melts? What's involved?
A phase change occurs, but the problem does not give the mass of the ice.
Right. Because it's the mass of ice that melts that you're looking for... Write out the formula that pertains to that phase change. Which of the variables do you you have values for?
How much heat is removed from from the lemonade when it cooled from 20C to 0 C?
Chet
gneill: Ok, so the formula that pertains to that phase is ΔQ = Lm. I know that L is the latent heat of fusion for water so it is 333 kJ/kg. Would the change in heat be the 3.38 kJ?
Chestermiller: I found the change in heat for the lemonade form 20-0 °C to be 83.38 kJ.
Sorry, i meant the 83.38 kJ
Yes. You calculated the heat that needed to be extracted from the lemonade in order to cool it to 0C, and that heat had to go somewhere. Clearly it went to melt some of the ice, providing the heat of fusion for the process.
So if the heat removed from the lemonade was 83.38 kJ, and the amount of heat required to melt 1 kg of ice is 333 kJ/kg, how many kg of ice have to melt?
Chet
Right, so I got 83.38 kJ/(333 kJl/kg) = .25 kg. So .25 kg. Is this right?
Yes.
Great! Thank you Chestermiller and gneill!
  • · Replies 17 ·
