How Much Paint Is Needed for a Hemispherical Dome?
6 replies · 12K views · last reply
Weave
Use linear approximation to estimate the amount of paint in cubic centimeters needed to apply a coat of paint 0.100000 cm thick to a hemispherical dome with a diameter of 45.000 meters.
[tex]Surface Area of sphere=4\pi(r^2)[/tex]
Since it is hemipshereical, the surface area will be half
[tex]Surface Area of hemispherical dome=2\pi(r^2)[/tex]
[tex]dSA=4\pi(r)dr[/tex]
I converted 45m into 4500cm for the radius. I set dr=.1cm
and the radius to 4500cm.
The question says that 45 m is the diameter, not the radius.
Oops. Well I inputed 2250cm for the radius and it is still wrong
This time the problem is to determine a volume. So you want to estimate the change in volume if a hemisphere grows from diameter 45m to 45.002m.
As you have been told the DIAMETER is 45 m. so the radius is 22.5 m= 2250 cm. In addition, YOU said
Since it is hemipshereical, the surface area willbe half
but then say
Shouldn't it be
[tex]dSA= 2\pi r^2 dr[/tex]?
but then say
You don't want Surface area, you want VOLUME. The volume of a sphere is [itex]\frac{4}{3}\pi r^3[/itex]. The differential is [itex]dV= \frac{4}r^2 dr[/itex] which is exactly the same as the surface area times the "thickness" dr. I thought that was what you were doing when you quoted the formula for surface area!
