HOw much power is drawn from a one volt battery?
15 replies · 4K views
jersey
each bulb in the circuit has a resistance of one ohm. how much power is drawn from the one volt battery?
to see the circuit diagram, click on this link:
it is problem 16 on page 123
To see the circuit diagram, go here:
http://www.lightandmatter.com/bk4c.pdf
GO to the link, scroll to page 123, and the diagram is problem 16.
Ohms Law
Loop rule
Junction rule
I have
D=B+E
A+B=C
and using Loop rule three times:
Va+Vc=1
Vd+Ve=1
Va=Vd+Vb
but i can't go on to solve the the five equatios cause i get lost. Can you help me?
jersey said:
Ohms Law
Loop rule
Junction rule
I have
D=B+E
A+B=C
Since you know the resistances, you can rewrite these in terms of the voltages.
For example, D = Vd/Rd, etc.
. . . and using Loop rule three times:
Va+Vc=1
Vd+Ve=1
Va=Vd+Vb
Shouldn't that middle equation be
Vd + Ve + Vf = 1​
regarding the middle equation, i assumed e anf F to be one single bulb with a resistance of 2 ohms.
I'm not sure how to re wrie each in relation to volatge like you say? Can you help?
Okay.
Sure.
From Ohm's law, we know the current through bulb D is
D = Vd / Rd​
So we can replace D in the equations with Vd/Rd instead.
I.e., instead of
D = B + E​
we get
Vd/Rd = B + E​
Then do the same for B and E.
Ok, so my new equations are:
Vd/Rd=B+E
Which becomes
Vd/Rd=Bd/Rb+Ve/Re
Yes, good. Here are two more things to do:
1. Since you know what Rd, Rb, and Re are, you might as well put those numbers into the equation.
2. Do the same thing for the A+B=C equation.
After doing those, try to solve for the 5 unknowns Va, Vb, etc.
I'm logging off for the night, so good luck.
Substituting Rd, Rb and Re = 1 into equation gives:
Vd/1=Bd/1+Ve/1
A+B=C
becomes ?
sorry, I'm trying!
Vd/1=Bd/1+Ve/1
Okay, let's work some more with that equation before moving on.
Doesn't Re=2, since you have combined e and f into one single bulb with a resistance of 2 ohms?
What is "Bd"? I think you meant to write Vb there.
Also, a simpler way to write "Vd/1" would be ____?
Redbelly98 said:
... a simpler way to write "Vd/1" would be ____?
jersey said:
Vd^-1
What? No. Look at these examples:
[tex]\frac{1}{1} = 1[/tex]
[tex]\frac{2}{1} = 2[/tex]
[tex]\frac{3}{1} = 3[/tex]​
You're just dividing each number by 1, so you get the same number.
[tex]\frac{Vd}{1} \ = \ ?[/tex]​
jersey said:
Vd=Vb+Ve
Almost. Just one little error to address:
