How Much Work Is Done on a Mass by a Time-Varying Force?
The problem involves calculating the work done on a mass by a time-varying horizontal force defined by the equation F(t) = (1.00 t + 0.250 t^2) Newtons, applied over a duration of 5 seconds on a 10.0 kg mass that starts from rest.
  • Participants discuss the integration of the force function to find work, with one participant initially calculating work using an incorrect integral. Another participant points out the need to integrate with respect to displacement rather than time.
The discussion is ongoing, with participants exploring different methods to approach the problem. Some have suggested using impulse and specific formulas for work, while others are clarifying the correct integration approach needed for this scenario.
There is a mention of the initial condition of the mass being at rest, which influences the application of certain formulas. The participants are also navigating the distinction between integrating with respect to time versus displacement.
XwakeriderX
A time-varying horizontal force is given by,
The force is applied from 0 to 5.00 seconds on a 10.0 kg mass which is initially at rest but is allowed to slide freely with only this one horizontal force acting on it. How much work is done on the mass by force F during the 5 seconds?
W=Integral (from Xi to Xf) Fxdx
W=(t^2)/2 + (t^3)/12 from 0 to 5
W=22.917
That is what i got from integrating.. But the answer is 26.3
Hi XwakeriderX! :smile:
(have an integral: ∫ and try using the X2 and X2 icons just above the Reply box :wink:)
No, that's ∫ F dt, and (as you say) you need ∫ F dx …
try again :smile:
Ah okay i got it! i used impulse then apllied W=Pf^2/2M
remember of course that this isn't a general formula, it works here only because vi = 0 …
generally ∆W = ((vi + P)2 - vi2)/2m = (P2 + 2viP)/2m :wink:
