How one can deduce the existence of antiparticles
The discussion revolves around the deduction of the existence of antiparticles from the Klein-Gordon equation. Participants explore the implications of the equation's solutions, particularly regarding the interpretation of negative energy states and their relation to antiparticles.
  • One participant questions why the negative root of the energy-momentum relation cannot be ignored and why it is interpreted as negative energy and momentum.
  • Another participant asserts that since antiparticles have been experimentally found, the theoretical deduction from the Klein-Gordon equation is significant.
  • A participant provides the general solution of the Klein-Gordon equation and discusses the interpretation of field operators in terms of particle and antiparticle creation.
  • Concerns are raised about whether the energy must be considered negative due to the presence of negative signs in the exponentials of the solutions.
  • One participant references Feynman's perspective that antiparticles can be viewed as particles with positive energy moving backwards in time.
  • There is a discussion about the conventions used in physics versus electrical engineering regarding time dependence in exponential functions.
Participants express differing views on the interpretation of negative energy solutions and the significance of the signs in the exponential functions. The discussion remains unresolved, with multiple competing interpretations present.
Participants note that earlier treatments of the Klein-Gordon equation did not involve quantization of the field, which may affect the interpretation of solutions in terms of particle creation and annihilation.
tommy01
Hi together ...
I wonder how one can deduce the existence of antiparticles from the Klein-Gordon equation.
Starting from (\frac{\partial^2}{\partial t^2} - \nabla^2 + m^2) \Psi(t,\vec{x})=0
one gets solutions \Psi(t,\vec{x})=\exp(\pm i (- E t + \vec{p} \cdot \vec{x})) leading to E^2=p^2 + m^2. You need the plus/minus in the exponential to get a complete system of solution functions but why you can't just ignore the negative root of the enegry-momentum relation and why you interpret the exp(- ...) as negative momentum and negative energy? why you can't just say the energy is always positive but the functional dependence is exp(+ ...) respectively exp(- ...)?
thanks and merry christmas.
Since anti-particles have been found experimentally, what is the point of your assertion?
that was my point ...
I know that they have been found experimentally. But it is always quoted as a great triumph of theoretical physics that antiparticles were predicted on grounds of the Klein-Gordon equation or the Dirac-Equation respectively.
The general solution of the KGE is:
<br /> \Psi(t, \vec{x}) = \int{\frac{d^{3}k}{(2\pi)^{3} 2 \omega} \left[a(\vec{k}) \exp\left(\iota (\vec{k} \cdot \vec{x} - \omega t)\right) + a^{\dagger}(-\vec{k}) \exp\left(\iota (\vec{k} \cdot \vec{x} + \omega t)\right)\right] }, \; \omega = +c \sqrt{k^{2} + \left(\frac{m c}{\hbar}\right)^{2}}<br />
If we interpret \Psi(t, \vec{x}) = \Psi^{\dagger}(t, \vec{x}) as a field operator creating an excitation of the real scalar field at the space-time point (t, \vec{x}), then a(\vec{k}) creates a particle with momentum \hbar \vec{k} and energy \hbar \omega, while a^{\dagger}(-\vec{k}) creates an antiparticle with the same energy and momentum.
Thanks. Thats a linear superposition of the fundamental solutions i cited above, but as you wrote \omega and thefore the energy is positive and there is no need for negative energy states called antiparticles. Or did i misunderstand something?
edit:
Back when they dealt with the Klein-Gordon equation. They didn't quantise the field, so there is no interpretation in terms of creation and annihilation operators.
notice the sign in front of t in both of the exponentials.
yes, but as i mentioned earlier, why does this sign carry over to the energy? why don't say the energy is positive but the functional dependence, to get linearly independent solutions, is exp(- ...) respectively exp(+ ...)?
thanks for your help and please excuse my problems understanding that point.
As far as I know, according to a fundamental paper by Feynman, antiparticles can be regarded as particles with positive energy, but moving backwards in time.
thank you. i also heard this statement, but it's the same story i think. only this time the sign is carried over to the paramter t instead of the energy.
i'll try to make my point clear:
although the solutions are
<br /> \Psi(t,\vec{x})=\exp(\pm i (- E t + \vec{p} \cdot \vec{x}))<br />
you don't say the energy can take on imaginary values only because there is an i in the exponential. it's simply part of the solution function. so why is a minus sign treated differently?
I'm afraid I don't understand what you are trying to say.
my point is:
you say that there are negative energy solutions because, as you showed, the general solution bears a plus AND a minus sign in the exponent. but it seems to me it would be the same to say the energy can be imaginary because there is an i in the exponent. i simply don't get the point why you have to interpret the minus sign as part of the energy expression and not just as a part of the functional dependece of the solution like the i.
greetings.
IF you have a time dependence like this:
<br /> \exp{(-i \, \omega \, t)}<br />
then \hbar \omega is the energy associated with such propagating perturbation.
O.k. so everything in the exponent multiplied by t except the -i is the frequency \omega. As E=\hbar \omega the negative energy comes from the negative frequency. Mhh i think i probably got it although there are many cases i remember where the time dependence was \exp(i \omega t) and no one thought of a negative energy.
nonetheless thanks for your patience and help.
In Physics, the convention is to use \exp{(-i \omega t)} as time dependence. In Electrical Engineering, it usually is \exp(2 \pi j f t) (they use j as the imaginary unit). Regardless of the convention, there are two terms in the expression - one with a plus sign and one with a minus sign. One of them must correspond to negative frequency. However, notice that the sign in the expansion coefficient a^{\dagger}(-\vec{k}) is also reversed. Thus, instead of interpreting this as negative energy, people interpreted it as moving backwards in time.
  • · Replies 32 ·
  • · Replies 113 ·
14K
