How quickily does a photon reach c?
  • Context: Undergrad
  • Thread starter Thread starter Neghentropia
    Photon
27 replies · 5K views
Neghentropia
Hi,
I have a very dumb question in my head: when a photon gets emitted by a source, how long does it take to reach c?
the fact it has no mass makes me thinking the acceleration is instantaneous (t=0) but this is from a classical physics point of view (and I also know that around speed of light few things go as it would be intuitive to think them going)
Neghentropia said:
Hi,
That is an excellent question.
I have been thinking about this puzzle for a while.
I do not think anyone else thought about this question,
or most people simply gave up.
But my suspicion is, the photon emerges with constant velocity c
from whatever system it is trapped into. In other words, the acceleration
of the photon takes place inside the atom as it builds up energy to
leave the atom (I am here considering Bohr's atom).
I would like to hear thoughts about this from other minds.
mfb said:
It does not accelerate at all. It is produced as particle traveling with c, and it travels at c all the time.
and in those means where the photons travel slower than c? (i.e. everything except the void)
It isn't a dumb question, but "acceleration is instantaneous" is gibberish... Informative gibberish, though: As you correctly noted, instantaneous means t=0. That's not acceleration, it is just time. Acceleration is v/t, so if t=0, acceleration is undefined.
mfb said:
[The photon] does not accelerate at all. It is produced as particle traveling with c
The same thing applies to any other elementary particle produced in a decay or interaction process. A muon decays into an electron and two neutrinos, each of which has a certain energy and velocity at the moment of decay. They don't accelerate to those velocities.
Afterwards, of course, the decay products may accelerate or decelerate depending on the conditions. When a nucleus decays via beta-decay, the emitted electron starts out with a certain energy and velocity, but then slows down a bit as it recedes from the nucleus because of the Coulomb attraction.
According to the link I posted above "Those photons didn't really exist before. There aren't a fixed number of photons. They can be destroyed and created. The energy, momentum, and angular momentum they have were there beforehand, but not in the form of photons."
I think this is probably important to understand. C isn't just the "speed of light," but it is the maximum speed of other things as well, like the electrons that are running through the light bulb.
Do I have this about right?
-Dave K
Now, when a photon is transitioning through a boundary, it must accelerate right?
This mental image may explain why some here think that there's some acceleration happening. Imagine someone, call him John, throwing a ball. First the ball in John's hand is at rest, and later it travels through the air with some speed v. Somehow it must have accelerated from zero to v, and so there's an acceleration involved.
When a photon is emitted by another particle, this is not like John who held the ball before he emitted it. The ball existed before the throw, and so it had to "be somewhere". But the photon came into existence, and so it couldn't have had a speed before, since there was no "before" from its point of view.
I think many people find this thought to be quite a hurdle. How can something just come into being if it wasn't there before? If the photon was emitted, it must have been hiding somewhere. Even a conjurer who pulls a rabbit out of a hat had that rabbit hidden somewhere, it didn't just appear from nothing.
Photons aren't rabbits though, and they don't behave like rabbits.
ok. that's actually pretty straightforward once you deal with the fact that photons are "generated"
but the questions I posted above remains. what happens to those photons that are generated into a medium (i.e air, water, glass) where the light is slower than in the vacuum?
are they decelerated?
if yes, what happens to a photon crossing a sheet of glass into the vaccum? it slows down and than accelerates again?
Sorry to sound redundant, and I know you probably want a discussion - but the link I posted above pretty much answers all these questions.
(to repeat, it's here: http://van.physics.illinois.edu/qa/listing.php?id=2026)
-Dave K
When photons travel through a medium they travel at the speed of light,but their rate of propagation is slowed by being absorbed and re-emitted by atoms.
It depends on the interpretation - see derek101's for one possible model.
You can describe light propagation with "effective" photons in matter as well - when photons enter a medium, they just have a different velocity inside (but no "acceleration process"!) than outside.
Note that my description is a simplified model and not the actual quantum mechanics behind that.
derek101's answer is very interesting.
it explains why the speed of a beam of photons travels at v<c, without the need to slow the actual photons down
here ( http://van.physics.illinois.edu/qa/listing.php?id=2026 ) I read:
"...As photons go into materials, they become something a little different, dressed in excitations of electrons. Assuming no reflection, the net energy E of the whole packet stays essentially the same, since the frequency f doesn't change and the relation E=hf is universal. However, the wavelength λ becomes shorter, so the momentum p of the packet goes up, since p=h/λ is also universal. (The momentum conservation is maintained by a slight recoil of the whole material.)
So since p goes up and v goes down, if you define inertial mass as p/v, it goes up by a factor (c/v)2=n2, where n is the index of refraction. In a typical material with electric but not magnetic susceptibility at optical frequencies, this is just a factor of ε, the electric susceptibility..."
I assume the v that goes down is the v of the beam of light, not the v of the actual photons, right?
Neghentropia said:
owhat happens to those photons that are generated into a medium (i.e air, water, glass) where the light is slower than in the vacuum?
From the Frequently Asked Physics Questions section at the top of this forum:
https://www.physicsforums.com/showthread.php?t=511177
Question.So does the model I described work ok for gas and liquids?
A photon entering a solid is no longer a particle until it is re-emitted/re-created.
Liquids are very similar to solids, and gases can behave similar, too (if the wavelength is long compared to the typical distances between atoms).
I would imagine it is like you describe. Although I can't quite grasp the meaning of a photon being absorbed by a phonon, given the latter is a quasiparticle.
anyway, from this topic as a whole, I think I got that photons, no matter the medium they are travellig through are always going to speed = c. Aristotele would say it's their natural state :)
at this point I'm wondering: what happens to those photons that enter a black hole??
I'm tempted to believe a black hole core (where the photons are dragged by gravity) has no vibrational state, so there are no phonons to absorb the photons.
Maybe I'm asking something beyond our current knowledge?
i would like to discuss this question from the wave hypothesis of light.
an analogy. if a photon is a wave like a sound wave, then think of the
creation of a photon as the plucking of a string. as the string is plucked
a train of waves, sound waves are created. and then the question becomes
how quickly do the sound waves build up? anybody familiar with music
will recognize this as the attack time.
so now the acceleration question becomes a question about how quickly
the wave of a photon builds up. and i think that this may have real
significance,
significance,
But is this really a valid analogy for light?
For sound, you require that string to be there. Light requires no such medium.
Secondly, there is "build up" required to generate photons. After all, we have ample single-photon sources here. Are there "single photon" sources for sound? Have you ever heard of single-phonon sources for vibrational modes?
The wave picture breaks down rather easily here, and such analogy doesn't help.
Zz.
I think this will need a theory of quantum gravity.
Photons do not need phonons to get absorbed in a medium, but the central singularity (if it is one) cannot be described with current physics.
Although I very much doubt it... It could be C(m/s)/Planck Time(seconds)=5.5609185948589E+51 M/S^2
But, like I said. I doubt it.
dkotschessaa said:
.....I think this is probably important to understand. C isn't just the "speed of light," but it is the maximum speed of other things as well, like the electrons that are running through the light bulb.
-Dave K
careful there ;) electron drift through a conductor is actually very slow
there's been quite a bit of duiscussion on that in the past on this forum
do a search on electron drift
Dave
That is a great question. My thought...Compare the situation to water or sound waves. Both emerge from the disturbance at the velocities allowed by the medium. So maybe the answer is the time from the start of the disturbance to the time the wave starts to depart.
-Dave K
Neghentropia said:
Hi,
You know that's not a dumb question..
Anyway, the relation E= hck is only true after an amount of time h/E (due to the Heisenberg uncertainty relation, DE DT > h), and so that's the amount of time it takes to reach c
