How reconstitute a conic equation by 4 roots?
  • Context: Undergrad
  • Thread starter Thread starter Bruno Tolentino
    Roots
4 replies · 1K views
Bruno Tolentino
Given two points in x-axis, a and b, is possible formulate a quadratic equation whose roots intersects a and b: (x-a)(x-b)=0
So, is possible make the same with a conic equation? Given 4 points, two in x-axis (a and b) and two in y-axis (c and d), is possible reconstitute a conic equation whose roots in x and y are a, b, c and d?
Mathematics news on Phys.org
Not uniquely. This is [itex]x^2- (a+ b)x+ ab= 0[/itex]. Multiplying the entire equation by any non-zero number gives another quadratic equation having the same roots.
If you want the quadratic function with leading coefficient 1, given by [itex]y= x^2+ bx+ c[/itex] then you need to determine two values, a and b. That requires two linear equations which you can get by replacing x and y with values of two points, not just where the graph crosses the x-axis.
A general conic is of the form [itex]ax^2+ bxy+ cy^2+ dx+ ey+ f= 0[/itex]. Even assuming a= 1 we have five coefficients, b, c, d, e, and f, to determine. That will require five points, not just four.
If you want the quadratic function with leading coefficient 1, given by [itex]y= x^2+ bx+ c[/itex] then you need to determine two values, a and b. That requires two linear equations which you can get by replacing x and y with values of two points, not just where the graph crosses the x-axis. A general conic is of the form [itex]ax^2+ bxy+ cy^2+ dx+ ey+ f= 0[/itex]. Even assuming a= 1 we have five coefficients, b, c, d, e, and f, to determine. That will require five points, not just four.
I want ANY conic equantion that intersects a, b, c and d! And, more importante: I want to write this conic in the format (x-a)(x-b) + (y-c)(y-d) + (x-a)(x-d) = 0! Or, in some format like this...
Since you know what "conics" are, surely you know that the graphs of conics are one of:
ellipse,
circle,
parabola,
hyperbola,
a single straight line,
two parallel straight lines,
two intersecting straight lines.
(The last three are "degenerate conics")
NONE of those cross the x-axis (or any horizontal straight line) more than twice so what you are asking for is impossible.
I don't believe HallsOfIvy read your question correctly. Given two x-intercepts a and b, and two y-intercepts c and d, there are many conics that meet this requirement: circles, ellipses, and hyperbolas. The only conic that doesn't satisfy the requirements is a parabola.
