- 11,089
- 3,935
Zafa Pi said:Indeed there is nothing mysterious in how to calculate the correlations for an entangled pair, QM gives a clear recipe. Nonetheless, I find that nature is in accord with those correlations extremely mysterious and I am in good company. Don't you find that masses experience gravitational attraction mysterious in spite of knowing how to calculate the force.
I think before making statements like that a bit of thought needs to be put into the nature of explanation. An explanation assumes some things to explain others. Every explanation, every single one, has that 'mysterious' aspect to it. Its how you react to it that determines your attitude - its very personal and not science.
Regarding gravity - GR explains that attraction as the result of space-time curvature which in modern times is known to be more or less implied by the very intuitive principle of no prior geometry - why should nature single out one geometry over another? Still its an assumption and how you react to it determines if its mysterious or not - personally for me its not mysterious - but that's just me - although I suspect the vast majority would feel that way as well.
I post this a lot because I think its very important (those that have seen before just ignore it - its purely to make a point):
https://arxiv.org/pdf/quant-ph/0101012.pdf
QM can be presented in such a way, like the principle of no prior geometry, so its not 'mysterious'. From that the different kinds of statistical correlations follow. In particular as the above paper shows its the requirement of continuous transformations between pure states that takes the place of no prior geometry. It turns out that is equivalent to having entanglement:
https://arxiv.org/abs/0911.0695
Its entirely how you view and react to it - 'mysterious' is a human reaction - nature doesn't care a hoot and certainly science doesn't.
Thanks
Bill
