How to abstractly prove a Laplace transform identity?
3 replies · 2K views
Eclair_de_XII
"Suppose that ##F(s) = L[f(t)]## exists for ##s > a ≥ 0##.
(a) Show that if c is a positive constant, then
##L[f(ct)]=\frac{1}{c}F(\frac{s}{c})##
##L[f(t)]=\int_0^\infty f(t)e^{-st}dt##
##L[f(ct)]=\int_0^\infty f(ct)e^{-st}dt##
D: ##e^{-st}## I: ##f(ct)##
D: ##-e^{-st}## I: ##\frac{1}{c}F(ct)##
I: ##F(ct)##
##L[f(ct)]=\int_0^\infty f(ct)e^{-st}dt=(\frac{1}{c}e^{-st}F(ct))+\frac{1}{c}\int_0^\infty e^{-st}F(ct)dt##
D: ##F(ct)## I: ##e^{-st}##
D: ##cf(ct)## I: ##-\frac{1}{s}e^{-st}##
##L[f(ct)]=\int_0^\infty f(t)e^{-st}dt=(\frac{1}{c}e^{-st}F(t))+\frac{1}{c}(-\frac{1}{s}e^{-st}F(ct))+\frac{c}{s}\int_0^\infty e^{-st}f(ct)dt##
##\frac{s-c}{s}\int_0^\infty f(ct)e^{-st}dt=(\frac{1}{c}e^{-st}F(ct))+(-\frac{1}{cs}e^{-st}F(ct))##
##L[f(ct)]=\frac{s}{s-c}(\frac{1}{c}(e^{-st}F(ct)-\frac{1}{s}e^{-st}F(ct))=\frac{s}{s-c}(e^{-st}F(ct))(\frac{1}{c}-\frac{1}{s})##
##L[f(ct)]=\frac{s}{s-c}(e^{-st}F(ct))(\frac{s}{cs}-\frac{c}{cs})=\frac{s}{c}e^{-st}F(ct)##
Can anyone tell me what it is I'm doing wrong?
Try ∫0f(ct)e-stdt = ∫0f(ct)e-s/c⋅ctdt = 1/c∫0f(h)e-s/c⋅hdh, where h=ct.
Note: If c is negative, you have to take into account the change of limits of the integral. Since it was stated that c>0, that is not a concern here.
This is a straightforward consequence of integration by substitution. First, to avoid confusion, define [itex]g(t) = f(ct)[/itex]. Then [tex]L[g(t)] = G(s) = \int_0^\infty g(t)e^{-st}\,dt = \int_0^\infty f(ct)e^{-st}\,dt.[/tex] Now set [itex]ct = u[/itex] and compare to [tex] F(p) = \int_0^\infty f(u)e^{-pu}\,du.[/tex]
Thanks for the help, everyone. I couldn't have finished the homework without it.
