How to Approach Lightlike Compactification Problem 5?
  • Thread starter Thread starter ehrenfest
    Compactification
18 replies · 6K views · last reply
ehrenfest
I am trying to do problem 5 at the following website:
http://www.myoops.org/twocw/mit/NR/rdonlyres/Physics/8-251String-Theory-for-UndergraduatesSpring2003/F4BA42A3-4DD9-402F-BDA8-6D5CB14B0FAF/0/ps1.pdf
I got for (b)
[tex]x' ~ \gamma \left( \gamma (1 -\beta^2) x'^0 + 2 \pi ( 1- \beta) R \right)[/tex]
and I got a similar identification for ct'.
For part (c), he wants us to find an identification in which the space coordinate is identified but the time coordinate is not. Does that mean is he asking to find x' ~ 0? x' ~ x' ? By using B_s as a variable and holding everything else constant?
I think that you have a mistake in your latex, but, from what I can see, I think that I get something quite different.
I left out an identification sign.
[tex]x' tilde \gamma \left( \gamma (1 -\beta^2) x' - 2 \pi ( 1- \beta) R \right)[/tex]
That does not make it quite different though. But your right I think that is wrong.
OK. So, I can find the non-primed coordinates in terms of the primed coordinates and plug that into the identification. Is it possible to isolate to then isolate the each primed coordinate on one side? Are operations to both sides allowed on identifications?
BTW what is the tilde syntax in latex
Use \sim. (Boy, was I ever wrong at first)
Do you mean
[tex]x'^0 \sim \gamma \left( \gamma (1 -\beta^2) x'^0 - 2 \pi ( 1- \beta) R \right)?[/tex]
If so then, your result, after simplification, is much closer to my result than I realized.
Shortly, after Zwiebach came out, I started working through it systematically, with the intention of finishing the whole thing. I only made it through the first six chapters before life intervened. I did, however, stuff my hand-written solutions to many of the exercises and problems for the first five chapters into a file folder that, despite moving moving between cities a number of times in the last few years, I somehow have not managed to lose.
I compared your result to the last line of my solution without actually thinking. :rolleyes: We differ by only one sign - I got
[tex]-2 \pi ( 1+ \beta) R \right)[/tex]
To simplify your expression, multiply the outside [itex]\gamma[/itex] through, and use
[tex]\gamma = \frac{1}{\sqrt{1 - \beta^2}} = \frac{1}{\sqrt{\left( 1 - \beta \right) \left( 1 + \beta \right)}}[/tex]
I'm not sure whose sign is correct, as both give nice "Doppler-shift" results. I'll have another look.
Do you mean
Your sign is right.
So, the complete answer for (a) is
[tex]x'^0 \sim \gamma \left( \gamma (1 -\beta^2) x'^0 - 2 \pi ( 1+\beta) R \right)?[/tex]
[tex]x'^1 \sim \gamma \left( \gamma (1 -\beta^2) x'^1 + 2 \pi ( 1-\beta) R \right)?[/tex]
Simplified, this is
[tex]x'^0 \sim \left( x'^0 - 2 \pi ( 1-\beta)^{-1} R \right)?[/tex]
[tex]x'^1 \sim \left( x'^1 + 2 \pi ( 1+\beta)^{-1} R \right)?[/tex]
So, for part (c), I get R_s^2 = R^2/gamma^2. How about you?
ehrenfest said:
[tex]- 2 \pi ( 1+\beta) R \right)?[/tex]
Not quite; careful with the square roots.
I double-checked everything and I cannot find any problems with my expression for [tex]x'^0[/tex] (= ct). So, if you're sure its wrong I'll post all my work. Just let me know.
OK, maybe you should show how you got the term I referenced in my last post.
We know that [tex]x'^0 = \gamma(x^0 - \beta x')[/tex] and that
[tex]x'^1 = \gamma ( -\beta x^0 + x')[/tex]
Do you agree that
[tex]x ^0 = (x'^0 +\beta x' \gamma)/\gamma[/tex] and that
[tex]x^0 = (x'' - \gamma x')/(-\gamma \beta)[/tex]
just by rearranging the first two equations in my post.
This allows us to solve for x^0 and x^1 in terms of primed coordinates.
I get x^0 = (\beta x'^1 + x'^0)/(\gamma - \gamma \beta ^2) and
x^1 = (x'^1 + \beta x'^0)/(\gamma - \gamma \beta ^2)
We can then rewrite the identification
[tex]x'^0 = \gamma(x^0 - \beta x') \sim \gamma(x^0-2\pi R - \beta (x^1 +2\pi R))[/tex] by replacing the unprimed coordinates on the rhs of above with the expressions I found for them in the previous two equations
Sorry, I posted the wrong term, thus misleading you.
I think there is a mistake going from
[tex]x'^0 \sim \gamma \left( \gamma (1 -\beta^2) x'^0 - 2 \pi ( 1+\beta) R \right)[/tex]
to
[tex]x'^0 \sim \left( x'^0 - 2 \pi ( 1-\beta)^{-1} R \right).[/tex]
I think there is a problem with the term
[tex]- 2 \pi ( 1-\beta)^{-1} R .[/tex]
to
You're right. It should be
[tex]x'^0 \sim \left( x'^0 - 2 \pi \sqrt{ \frac{1+\beta}{1-\beta}} } R \right).[/tex]
and
[tex]x'^1 \sim \left( x'^0 + 2 \pi \sqrt{ \frac{1-\beta}{1+\beta}} } R \right).[/tex]
Good.
Now, I really do have a small problem
with the
[tex]2 \pi ( 1-\beta) R[/tex]
term in
[tex]x'^1 \sim \gamma \left( \gamma (1 -\beta^2) x'^1 + 2 \pi ( 1-\beta) R \right).[/tex]
George Jones said:
Good.
with the
term in
I see. It should be
[tex]x'^1 \sim \gamma \left( \gamma (1 -\beta^2) x'^1 + 2 \pi ( 1+\beta) R \right).[/tex]
So
[tex]x'^1 \sim \left( x'^1 + 2 \pi \sqrt{ \frac{1+\beta}{1-\beta}} } R \right).[/tex]
For c then, I think that we get the desired S' with
[tex]\gamma R = \beta R_s[/tex]
I didn't get this, but I did get something very close to this.
ehrenfest said:
[tex]R = \beta R_s \gamma[/tex] ?
I get a negative sign.
OK. Well it should really be +/- because we have [tex]R^2 = B^2 R_s^2 \gamma^2[/tex] and then we take the square root of both sides, right?
