How to calculate 167^0,2 without a calculator
  • Thread starter Thread starter kev.thomson96
    Calculator
The calculation of 167^0.2, equivalent to the fifth root of 167, can be approached through various methods. One effective technique involves estimating the fifth root by testing values between 2 and 3, ultimately refining the estimate using the binomial expansion. Alternatively, logarithmic calculations can be employed, where log(167) is expressed as log(1.67) + 2, allowing for the multiplication of log(167) by 0.2 to find the desired result. Both methods yield a practical understanding of calculating non-integer exponents without a calculator.
  • Understanding of fractional exponents and roots
  • Familiarity with logarithmic functions and properties
  • Basic knowledge of binomial expansion
  • Ability to perform manual calculations and estimations
  • Learn about the properties of fractional exponents in algebra
  • Study logarithmic functions and their applications in calculations
  • Explore binomial expansion and its use in approximating roots
  • Practice manual calculations for non-integer powers and roots
Students, educators, mathematicians, and anyone interested in enhancing their skills in manual calculations and understanding exponentiation without digital tools.
kev.thomson96
I was wondering how that could be done.
I tried 0,2 ---> 1/5, then 167 ^(1/5) , which should lead to 5√167 (fifth root of 167) , but I can't seem to move on from there
Mathematics news on Phys.org
0,2= 1/5 so you are asking for the principal fifth root of 167. I note that 2^5= 32 and 3^5= 243 so I would next try 2.5. 2.5^5= 97.65625 (yes, I did that "by hand"!). That's less than 167 so I would try 2.75 next and keep going until I got sufficient accuracy.
I did it using the first two terms of a binomial expansion.
$$167^\frac{1}{5} = \left( 243 - 76 \right) = 243^\frac{1}{5} \left(1 - \frac{76}{243} \right)^\frac{1}{5} \doteq 3 -\frac{1}{5} \frac{76}{81}$$
Are you allowed to use log tables?
I don't think so, but I'd like you to elaborate if you can solve it with log.
If x= 167^{0,2} the log(x)= 0,2 log(167).
So: look up the logarithm of 167 in your log table, multiply by 0,2 then look up the number whose logarithm is that.
Note: you will not find logarithm of just 167. log table I have here (base 10) contains logs of numbers between 1 and 10, so you will need to express 167 as 1.67*100 and then log(167) = log(1.67)+2.
Not that it changes the general idea, just makes it a little bit more convoluted.
"log table I have here..."
Not sure I could put a finger on a log table if pressed. It reminds me of a conversation I had many years ago (1990-ish) with a historian
Historian: "Do you have a slide rule I can use?"
Me: "No, I haven't had one for many years."
Historian: "I thought every mathematician had one."
Me: "Before you go, do you have any papyrus I could have?"
Historian: "Why would you think we still use that?"
He didn't get my humor.
I haven't used any of mine for some time, but I still have a few slide rules around.
I still have two, but they are in my house, on the same shelves as the old roll film cameras my father had 85 years ago.
  • · Replies 22 ·
  • · Replies 59 ·
63K
