How to calculate a harmonic of a square wave
To calculate the 5th harmonic of a square wave with a fundamental frequency of 200Hz, the correct formula is 1/9 * sin(2 * π * 9F * t), where F is the fundamental frequency. The harmonic frequencies are determined by the relationship fn = n*f1, meaning the 5th harmonic corresponds to 9 times the fundamental frequency. The variable 't' represents time in the sinusoidal function. Additionally, a factor of 4/π is necessary to achieve a square wave of unity amplitude.
bigfattyfatfat
Hi,
I'm a bit of a newbie to additive synthesis.. I just want to clarify that I am doing the correct calculation before continuing.
If I wanted to calculate the 5th harmonic of a square wave (the fundamental freq. being 200Hz and the amplitude of the fundamental being 1)
would the calculation be
1/5 * sin (2 * 3.14 * 1000) =
Thanks in advance
there's a 4/pi and a "t" missing in there somewhere ...
other than that, yes.
Thanks.
Actually I've just realized the 5th harmonic would be 9, so it would be
1/9 * sin (2 * 3.14 * 9F * t) =
But do you know what the 't' is equal to?
Thanks
bigfattyfatfat said:
Thanks.
Thanks
No, convention is that the nth harmonic is harmonically related to the first (the fundamental) by fn = n*f1.
"t" is time. You have a square wave that is a summation of harmonics, each of which is also a function of time (a sinusoidal one).
You still don't have a 4/π in your formulas ... you need it to get a square wave of unity amplitude.
