How to calculate a sink using spherical coordinates
7 replies · 2K views · last reply
Addez123
$$A = grad(\frac{1} {\sqrt{(x-3)^2+(y+1)^2+z^2}} + xy^3)$$
Calculate the flow out of a sphere with radius 3, centered at (2, 1, 1)
Possibly gauss theorem
The issue is that the singularity is not in the center of the sphere.
So how would I calculate it?
I have a few questions:
1. Can I calculate the terms separately like so:
$$A = grad(a+b) = grad(a) + grad(b)$$
2. If I use a spherical coordinate system with the center being at the singularity I can calculate the gradient of first term as
$$grad(a) = -1/r^2 e_r$$
The second term, xy^3, can be calculated with normal coordinates:
$$grad(b) = (y^3, 3xy^2, 0)$$
This creates a few issues though.
I need to convert BOTH those vectors into spherical coordinates with the center being (2, 1, 1).
In grad(b) I recon all I have to do is replace x with ##rsin\theta cos\phi - 2##?
Shouldn't I have to apply scale factors since I'm going from normal coordinates to sphericals?
in grad(a) I just have no idea how to do it.
e_r is not the same since I've moved the center of the spherical system.
So I have no idea how to solve it.
I COULD use spherical coordinates with center (2, 1, 1) and just insert those x, y, z values into A and brute force solve the equation but it really doesn't feel like what I'm suppose to do.
P.S. Sorry for posting so much, I have no class to go to or teacher to ask atm.
Orodruin said:
Hint: Divergence theorem.
Yes but how?
With spherical coordinates? If so what orgin (2,1,1) or (3, -1, 0)?
Addez123 said:
Yes but how?
The divergence theorem is coordinate independent.
So I solve the div A by doing ##1/r^2## and ##xy^2## separatly.
$$div grad(1/r^2) = 2/r^4$$
$$div grad(xy^3) = 2xy$$
Now I have the results in two different coordinates, neither of which represents a spherical coordinate system with the orgin at (2,1,1). So calculating a div across a sphere with the center (2,1,1) will require some for of conversion that I dont know how to do..
Orodruin said:
It is 1/r, not 1/r^2.
True!
$$div grad(1/r) = \frac 1{h_r h_\phi h_\theta} * (\frac d {dr} (\frac {h_\phi h_\theta}{h_r} \frac {dA}{dr}) + \frac d {d_\theta} ...) = 0$$
I excluded the ##d/d_\theta## and ##d/d_\phi## terms since they don't contribute to anything when A only has r components.
Since div = 0 the sink won't contribute to anything, nomatter what coordinate system i use?
In my textbook is says the contribution from the sink is ##-4\pi##, so I must've done something wrong still.
The expression for the divergence in spherical coordinates is only valid for r > 0. You need to treat the singularity of the coordinate system separately.
