Sneakatone
- 318
- 0
Sneakatone said:a) I converted 33 km/h ---> 33/3.6=9.16m/s
9.16/0.5=18.33 rad/s
b)2*1/2(1200kg)(18.33)^2=403186.68 J
Sneakatone said:formulas
a) angular velocity w=v/r
b)kenetic energy 2*1/2(I)(w)^2 since 2*I{initial}*w{initial}=I{final}w{final}
Sneakatone said:the formula for angular momentum is L=mvr in a circular orbit.
Sneakatone said:P=m*v
Sneakatone said:I don't suppose L=Iw would work since were trying to find w.
L=r*P might work since there's an origin .
Sneakatone said:for kinetic energy should I do
[1/2*Iw^2]-[1/2mv^2] to get the difference of initial and final kinetic energy?
Sneakatone said:when I used [1/2*Iw^2]-[1/2mv^2] it came out to
[1/2*(2500)(4.39)^2]-[1/2(1200)(9.16)^2]=-26253.24
can you get negative kinetic energy?
Sneakatone said:the amount of energy used for rotational was higher that when it was linear.
Sneakatone said:so is this method wrong?
Sneakatone said:I don't really notice any errors except removing the 1/2 from the final.
Sneakatone said:so it should be
[1/2mv^2]-[Iw^2]?
Dick said:You aren't really listening are you? It should be 2*[(1/2)mv^2]-[(1/2)Iw^2]. There are two cars and there's a (1/2) factor in the rotational energy as well.
Sneakatone said:using that equation i ended up with 52506.48 J, which is two times what I originally had.
