How to calculate conditional expectation E[g(x) | x>= Q] for x ~ exp(1)
The discussion focuses on calculating the conditional expectation $\mathbb{E}[g(x) | x \geq Q]$ for a random variable $X$ that follows an exponential distribution $X \sim \exp(1)$. The function $g(x)$ is defined as $$g(x) = \frac{A}{\exp(-bQ+c)}\Big(\frac{1 + \exp(-bQ+c)}{1 + \exp(-dx+c)}-1\Big)$$. The correct approach involves using the Law of the Unconscious Statistician (LOTUS) to derive the expectation through the integral $$\mathbb{E}[g[x]] = \int_Q^\infty g(x) f(x) dx$$, where $f(x) = e^{-x}$ is the probability density function of the exponential distribution.
  • Understanding of exponential distribution, specifically $X \sim \exp(1)$.
  • Familiarity with conditional expectation and its notation.
  • Knowledge of the Law of the Unconscious Statistician (LOTUS).
  • Ability to perform integration of functions involving exponential terms.
  • Study the derivation and applications of the Law of the Unconscious Statistician (LOTUS).
  • Learn about conditional expectations in probability theory.
  • Explore integration techniques for functions involving exponential decay.
  • Investigate other distributions and their conditional expectations for comparative analysis.
Statisticians, data scientists, and mathematicians interested in probability theory, particularly those working with exponential distributions and conditional expectations.
user_01
Given that $X$ is exponentially distributed continuous random variable $X\sim \exp(1)$ and $g(x)$ is as below. How can I find the Expectectaion of $g(x)$ for the condition that $x\geq Q$, i.e. $\mathbb{E}[g(x)\ | \ x\geq Q]$.
I suppose I should start by considering an event $\Phi$ such that $\Phi = \mathbb{P}[x \geq Q]$. However, I don't know how to go around this condition.
All constants are positive real values.
Is the following solution correct for the above question? If it is OK, then I have found the solution. But I will really appreciate if someone can let me know if the following method is correct.
$$\mathbb{E}[g[x]] = \int_Q^\infty g(x). f(x) dx$$
$$\mathbb{E}[g[x]]= \int_Q^\infty\frac{A}{\exp(-bQ+c)}\Big(\frac{1 + \exp(-bQ+c)}{1 + \exp(-dx+c)}-1\Big) e^{-x} dx$$
Hi user_01,
Yes, your proposed solution is correct. The relevant theorem here is known as the Law of the Unconscious Statistician (LOTUS). See here.
  • · Replies 0 ·
