How to calculate density matrix for the GHZ state
The discussion focuses on calculating the density matrix for the GHZ state, represented as |ψ> = (|000> + |111>)/√2. The density matrix is derived step-by-step, leading to a final matrix that reflects the entangled nature of the GHZ state. Participants explore the concept of reduced density matrices by separating the system into subsystems A and BC, questioning the validity of this decomposition. The conversation highlights the distinction between the original density matrix and the reduced density matrix, emphasizing that the GHZ state cannot be expressed as a separable product of its subsystems. Ultimately, the discussion seeks to clarify the interpretation of these matrices in the context of quantum measurements and entanglement.
Agrippa
The GHZ state is:
|\psi> = \frac{|000> + |111>}{\sqrt2}
To calculate density matrix we go from:
GHZ = \frac{1}{2}(|000> + |111>)(<000| + <111|)
GHZ = \frac{1}{2}( |000><000| + |111><111| + |111><000| + |000><111|)
To:
GHZ<br /> = 1/2[<br /> \left( \begin{array}{cc}<br /> 1 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> \end{array} \right)<br /> +<br /> \left( \begin{array}{cc}<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 1\\<br /> \end{array} \right)<br /> +<br /> \left( \begin{array}{cc}<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 1 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> \end{array} \right)<br /> +<br /> \left( \begin{array}{cc}<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 1\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> \end{array} \right)<br /> <br /> ]
And finally to:
<br /> GHZ = 1/2\left( \begin{array}{cc}<br /> 1 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 1\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 1 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 1\\<br /> \end{array} \right)<br />
But I see another author (p2) separates the Hilbert space into two subsystems GHZA⊗GHZBC and gets a "reduced" density matrix:
<br /> GHZ_A⊗GHZ_{BC} = 1/4\left( \begin{array}{cc}<br /> 1 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 1 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 1 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 1\\<br /> \end{array} \right)<br />
Can anyone explain what this final matrix represents, and how one calculates it?
That density matrix represents the mixed state:
\frac{1}{4}\big(|0,0,0\rangle\langle 0,0,0|+|0,1,1\rangle\langle 0,1,1|+|1,0,0\rangle\langle 1,0,0|+|1,1,1\rangle\langle 1,1,1|\big)
or more simply:
\frac{1}{4}\big(|0\rangle\langle 0|+|1\rangle\langle 1|\big)\otimes\big(|0,0\rangle\langle 0,0|+|1,1\rangle\langle 1,1|\big)
To figure that out, system A separates the density matrix into four equal square blocks (of size 4x4)
Of each block, system B separates the density matrix into four equal square sub-blocks (of size 2x2)
Of each sublock, the state of system C associated to those particular amplitudes of A and B are given.
Likes Agrippa
Thanks. I can (roughly, without yet drawing it up) see how you've constructed this expression from the final matrix I drew up.
jfizzix said:
or more simply:
Hmmm, I'm trying to work through this equation but am getting the wrong result:
<br /> 1/4\left( \begin{array}{cc}<br /> 1 &amp; 0\\<br /> 0 &amp; 1\\<br /> \end{array} \right)<br /> \otimes<br /> 1/4\left( \begin{array}{cc}<br /> 1 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 1\\<br /> \end{array} \right)<br /> = 1/4\left( \begin{array}{cc}<br /> 1 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 1 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 1 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 1\\<br /> \end{array} \right)<br />
But perhaps I'm just making a simple mistake somewhere. At least, I can kind of see what you've done: you've tried to find a density matrix that corresponds to system A, and a density matrix corresponding to system BC, such that putting them together (##\otimes##) gives you the final matrix from my first post.
Unfortunately I don't quite follow you here. In particular, the talk of systems A and B separating the matrix into blocks, and the talk of the state of C being given (but not A or B (or A versus BC)?). Does it relate in some way to the calculation I just made above?
My main confusion is this: take the original density matrix for the pure state. I understand that the diagonal terms represent probabilities for measurement outcomes: 0.5 and 0.5. I also understand (to a lesser degree) that the off-diagonal terms represent the system's ability to exhibit interference. So the density matrix for a pure state like GHZ has a clear interpretation. But how does one interpret the "reduced" density matrix for GHZA⊗GHZBC?
It is a simple mistake, easily rectified.
What's here the kronecker product in reverse order. If X is the first matrix you have here, and Y is the second matrix, then to get X\otimes Y, you should make a big matrix out of (in this case 4) copies of Y, and then multiply each copy of Y by the corresponding entry in X.
It looks like that you've done instead is make a big matrix out of... 16 copies of X, and then multiplied them by the corresponding entries of Y.
In short, you've found Y\otimes X instead of X\otimes Y.
Yes I see the mistake now, thanks. What I still don't understand is the relationship between original density matrix and the reduced density matrix. In particular, we know that the density matrix of the GHZ state is:
\frac{1}{2}( |000&gt;&lt;000| + |111&gt;&lt;111| + |111&gt;&lt;000| + |000&gt;&lt;111|)
We now want to break the system down into two systems (A and BC). But how do we know that this:
is a valid way to decompose the system? Why, for example, do we associate ##\frac{1}{4}\big(|0\rangle\langle 0|+|1\rangle\langle 1|\big)## with subsystem A? How do we know that this expression in any way represents subsystem A?
The product
is not a valid decomposition of the GHZ state:
The GHZ state is not separable into such a product or any other product. It's about as entangled as three-particle spin states get.
If one were to measure particle A of the GHZ state (in the 0/1 basis), the state one would get as a result would be:
\frac{1}{2}\big(|0\rangle\langle 0|\otimes|0,0\rangle\langle 0,0|+|1\rangle\langle 1|\otimes |1,1\rangle\langle 1,1|\big)
But in decoherence theory, isn't it standard to separate an entangled state into system state and environment state? I thought that something like that must be going on here. For example, I thought that GHZA⊗GHZBC amounted to something like treating systems B&C as the environment. Is that not right? I'm trying to figure out how to calculate the (reduced) density matrix called 'GHZA⊗GHZBC' from just the density matrix of the GHZ state.
(In case it helps, I'm ultimately trying to understand a particular definition of (integrated) information of a quantum state (see e.g. page 2), which is calculated via a function of the density matrix of the state and the reduced density matrices of its decompositions.)
That's useful, thanks. I've calculated it as follows:
<br /> 1/2\left( \begin{array}{cc}<br /> 1 &amp; 0\\<br /> 0 &amp; 0\\<br /> \end{array} \right)<br /> \otimes<br /> 1/2\left( \begin{array}{cc}<br /> 1 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0\\<br /> \end{array} \right)<br /> +<br /> 1/2\left( \begin{array}{cc}<br /> 0 &amp; 0\\<br /> 0 &amp; 1\\<br /> \end{array} \right)<br /> \otimes<br /> 1/2\left( \begin{array}{cc}<br /> 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 1\\<br /> \end{array} \right)<br /> = 1/2\left( \begin{array}{cc}<br /> 1 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0\\<br /> 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 0 &amp; 1\\<br /> \end{array} \right)<br />
I interpret the diagonal values as representing probabilities (0.5 chance for |000> and 0.5 chance for |111>) and the off-diagonal values as capacity for interference, which is zero given that we now have an eigenstate (either |000> or |111>).
But then I wonder what the two additional 1's on the diagonal of GHZA⊗GHZBC represent; and why the diagonal contains all ones in the case of GHZA⊗GHZB⊗GHZC = I/8.
