How to calculate molecular formula
  • Thread starter Thread starter BH20
84 replies · 23K views
Gokul43201 said:
I think it's the other way round.
yep, sorry.
n(NH3) 3,726.63 moles. n(O2) is 2,235.77moles.
Chemistry news on Phys.org
Yes, now if you multiply the equation
NH3(g) + 1.75 O2(g) -> NO2(g) + 1.5 H2O(g) (just changed fractions to decimals)
throughout by the number 2235.77/1.75=1277.6 , you get
1277.6 NH3(g) + 2235.77 O2(g) -> 1277.6 NO2(g) + (1.5*1277.6) H2O(g)
This converts the equation to a form that involves the actual number of moles in the reaction vessel. So, this says that all the O2 will get used up but only 1277.6 moles of NH3 will react. So the unreacted number is 3726.6 - 1277.6 = 2449 moles of NH3.
alright thanks..can we get to the the writing equations and balancing? Maybe that is the reason I did not pick this up abit better.
sinc sulphate + barium nitrate produces ...
gold (III) sulphate + barium chloride produces...
tin + antimony(V) chloride produces...
ferrous bromide + phosporic acid produces...
the complete combustion of ethene, C2H4 produces...
when writing equations, do you basically look at the ions? I do know though how the compounds come together.
You need to read up the different types of reactions...I cannot describe them all here. And you must understand valency, oxidation numbers, etc. Look up your elementary chemistry textbook.
Also see : http://members.tripod.com/~EppE/reaction.htm
Start at : http://members.tripod.com/~EppE/index.htm
Start from the intro and go through stoichiometry (and Gas Laws, if necessary)
PS : these pages take a while to load...thanks to a slow ad-server.
Yes, I'm aware of the different types of reactions. The issue is writing the equation.
For example, the first example:
zinc sulphate + barium nitrate produces
This is a double displacement reaction. obviously, and I know how to interchange them (come up with the product).
ZnSo4 + BaNO_3(2) produces BaNO3 + BaSo4
The issue is, when I produce the new compounds, what is the deciding factor in if its Ba_2NO3, etc... I thought it was the valency? is it?
Is there some sort of special valency for elements like nitrate? I know what it is for Nitrogen, but not nitrate, etc.
And if so, what if a an element has more than one valency states, which one do you use?
I understand that based on the reactants the products will vary based on the type of reaction it is.
Thanks
Yes it's the valency. If element A has valency x and element B has valency y. Then the compond formed by them will be [tex]A_yB_x[/tex]
ie. interchange the valencies. Now if x,y have some common factor, then you reduce this to the simplest ratio.
eg : Zn = 2; O = 2 => Compound = Zn2O2 = ZnO
Some elements exhibit more than one valency, though one of these is more common than the other. If not specified, you should assume the more common valency. But most sensible people specify the valency in such cases. eg: Fe(III), Cr(VI), Zn(IV)
Valencies of common radicals : NO3 = 1, SO4 = 2, PO4 = 3, CO3 = 2, OH = 1, SO3 = 2, NH4 = 1
PS : Check your double-decomposition reaction, and correct it.
You do the crossover though..right?
For example in that first example:
Zinc is +2, SO4 is -2 Ba is +2 NO3 is -1
So, let's look at ZnSO4. Since Zinc has a valency of +2, it will go across and should really be ZnSO4(2) and then, since SO4 is -2, the total should be Zn2SO42. As you said though, we want to reduce to the simplest ratio, so since its both 2's, we can just leave it like that, it would reduce to 1..right?
And then if we look at BaNO3...Barium is +2, so we crossover and it should make it NO3(2), NO3 has a valency of -1, so that means we don't put anything infront of Ba..so its BaNO3(2).
ZnSO4 + BaNO3(2) produces ZnNO3(2) + BaSO4
Is this right..and it already looks balanced..the question states to balance it too..so maybe its wrong?
One small issue for the elements with more valency's...is that I'm not really sure which one is the common.
So far so good ! And it is balanced, so there's nothing more to do there.
"I'm not sure which valency is more common"
Nor am I...that's why it's usually specified. But for Zn, II is more common than IV, and for Cr, II and III are more common than VI. Fe II and III are both fairly common. Cu, II more than I. It's only with the transition metals (d-block) that you see these multiple valencies.
ok..thanks
The second has:
Gold(III) Sulphate + Barium Chloride produces
Does the (III) mean we use the +3 valency, and if so, do we cross that over too?
So it would be:
Au2SO4(3) + BaCl2 produces Au2Cl3 + BaSO4
Does it look right, and if so, how would we balance it?
BH20 said:
ok..thanks
The second has:
Yes, always !
So it would be:
Mistake on the right side...find it. Then we can get to balancing.
For balancing an equation, you need to make sure there are an equal number of atoms of each element on the LHS and RHS. You cannot change the molecular formula to get this right. What you can do is change the coefficients (number of moles/molecules) before each compound.
dont see the mistake...Au is +3 (in this case anyways) Cl +2..so Au2Cl3
and then Ba is +2 and SO4 is -2, so it cancels out.
Gokul43201 said:
Cl valency is -1, not -2.
yep, my bad..dont know what made me think nit was -2.
Au2SO4(3) + BaCl2 produces AuCl3 + BaSO4
LS has to equal RS
LS= Au=2, SO4=3, Ba=1, Cl=2
RS= Au=1, SO4=1 Ba =1, Cl=3
Balanced:
Au_2(SO4)_3 + 3BaCl2 produces 2AuCl_3 + 3BaSO4
LS= Au=2, SO4=3, Ba=3, Cl=6
RS= Au=2, SO4=3, Ba=3, Cl=6
looks good to me.
I have some other ones to do which are different, more complex:
1. Zinc + mercurous nitrate produces - single displacement reaction.
Zn + HgNO3 produces Hg + Zn(NO3)_2
Balance:
Zn + 2HgNO3 produces 2Hg + Zn(NO3)_2
2. tin + Antimony(V) chloride produces - single displacement reaction.
Sn + SbCl4 produces Sb + SnCl4
Balance:
Looks fine. Altought Tin does have a valency of +2 and +4, but I think this one is right.
3. Calcium + water produces - synthesis reaction
Ca + H20 produces
not sure how this one comes together...pretty sure its not CaH20.
Found this on the net, but not sure why its like that:
Ca(s) + 2H2O(l) ——> Ca(OH)2(aq) + H2(g
Have a few more I will bring up.
4. Ferrous Bromide + Phosphoric Acid - not sure what type of reacion
FeBr + H3O4P produces
no idea how to do this one...
5. the complete combustion of ethene, C2H4 produces -
not sure either
6. calcium carbonate + hydrobromic acid produces - guess double displacement?
Ca2(Co3)_3 + HBr produces not sure
Balance:
Balance:
Ca + H20 produces
Always treat H2O as though it were written HOH, with H (valency +1) being the cation, and OH(valency -1) being the anion.
So, Ca + HOH ---> Ca(OH)2 + H but then H exists only as H_2
So, Ca + H2O ---> Ca(OH)2 + H2, and now balance this to get the above equation.
PS : When a metal exhibits more than two valencies (eg : Fe II and III), the lower valency is indicated by an -ous ending and the higher valency by an -ic ending. So Fe(II) is called ferrous and Fe(III) is calles ferric.
That's how you should know that the mercurous in (Q1) above is Hg(I) and not Hg(II)
Acids are made up of a H (cation) and any anion that is usually among Cl, Br, SO4, PO4, NO3, etc. The number of H atoms depend on the valency of the anion.
PO4 is -3. So phosphoric acid is H3PO4.
SO4 is -2. So sulphuric acid is H2SO4.
Cl, Br, NO3 are all -1. So you have HCl (hydrochloric), HBr (hydrobromic) and HNO3 (nitric acid).
Likewise, a base is usually made up of any common cation (Ca, Na, Mg, K, Cu, Zn, etc.) and OH (-1) as the anion. They are named as hydroxides. eg : Ca(OH)2 is calcium hydroxide, NaOH is sodium hydroxide.
When a hydrocarbon combusts, it is reacting with oxygen (O2) to give CO2 and H2O. So hydrocarbon + O2 ---> H2O + CO2. All you have to do is balance this. (Hint: First balance C and H, then do O)
Alright, at least I get how it comes together now, (like why its H3PO4, for some reasons I thought it was different because it was an acid) but I'm still not sure if I understand what it produces.
The first one for example:
FeBr + H3PO4 produces FePO4 + BrH3 ?
if you can show me that one..I usually get a hang of it when I see it.
Remember...H is (almost) always a cation (+ve valency). The convention is put put the cation before the anion (-ve valency). So it would be HBr and definitely not BrH3. Where did the 3 come from ? You're forgetting to assign the valencies and switch their positions.
Ferrous bromide should be FeBr2, since Fe is +2 (not +3, that would be ferric)
Phosporic acid is H3PO4.
They react via double-decomposition...so the products are Fe3(PO4)2 and HBr.
Now balance this.
Now balance this.
3FeBr2 + 2H3PO4 produce Fe3(PO4)2 + 6HBr
Not sure about question 5:
I think I got the last one though:
Written and Balanced: Ca2(Co3)_3 + 2HBr produces 2CaBr + H2CO3
6. How is it Ca2(Co3)_3 ? What is the valency of the CO3 radical ?
5. See bottom of post#50. C2H4 is a hydrocarbon - a compound having carbon and hydrogen.
oh, made a mistake...Ca is +2, and CO3 is -2. Here it is.
6. 2CaCO3 + 2HBr produces 2CaBr + H2CO3
and 5...
C2H4 + 202 produces 2H2O + CO2 ??
and 5...
Umm, CaBr ? Check that.
And for 5. recheck the Carbons.. you have 2 on the LHS and only 1 on the RHS. Use the Hint from #50.
5. C2H4 + 302 produces 2H2O + 2CO2
6. CaCO3 + 2HBr produces CaBr2 + H2CO3
I've done a lot of other questions, but I want to check with you if I did them properly..so some short questions for you, to see if I did them properly.
1. Asked me to find the number of atoms...
a) gave me just 52.5g of calcium metal..I put the g over the molarmass and then * it by 6.02* 1023molecules.
b) and c) parts gave me the number of moles, so I found the mass, and then again * by 6.02*1023
2. There was a question that asked to find the volume of a gas at -30degreescelsius and 0.75atm if it occupies a volume of 255L at 40degreescelcius and 1.25atm... I used the General Gas Equation. My question is, is it V1 or V2 that wer are finding..V1 right?
3. Also it asked me to compare a mixture of hydrogen and chlorine in a cylinder (without doing calculations), when it comes to:
a) relative mass..I said Cl is heavier (has bigger atomic mass)
b) average kinetic engery..I said Cl molecules have a higher kinetic enegery because its heavier.
c) the average speed...I said it is dependent on the temperature..but I'without doing calculations I don't know where you can find that info.
d)the temperature..not sure where to find that, but I said, Hydrogen is hotter because its a non-metal.
