How to calculate program execution time?
  • Thread starter Thread starter CodeMonkey
    Program Time
To measure program execution time in milliseconds while coding in Java, C++, and C# using Visual Studio, several methods are discussed. QueryPerformanceCounter() is highlighted as the highest resolution timer, though it may include overhead from other tasks. To mitigate this, adjusting thread priority with SetThreadPriority() can help. GetProcessTimes() is noted for excluding overhead from other processes, but it still captures interrupt overhead, which can skew results. The clock() function offers a more generic timing method, reporting time in milliseconds on Windows XP but is based on a 64hz ticker. For UNIX systems, the time command is recommended. For C#, users are advised to explore the appropriate namespace, class, and methods, and consider using profilers to analyze function execution times for performance issues. Various profilers are available for .NET and Java, some of which are free or offer trial versions.
CodeMonkey
I'm using VS and coding in Java, C++ and C#. What are the methods to use to display the time it takes for the program to execute in ms?
Technology news on Phys.org
I've used the following:
Highest resolution timer, but includes overhead from other tasks. Still I found it to be the best. Using SetThreadPriority() to bump up priority should reduce overhead from other tasks.
GetProcessTimes()
Supposed to exclude overhead from other processes, but seems to include interrupt overhead. timeBeginPeriod() (requires a later timeEndPeriod()) can be used increase the tick rate, but this also seems to increase the reported time, indicating that interrupt overhead is included in the process times.
clock()
A more generic time call. On Windows XP, reports time in milliseconds, but appears to be based on a 64hz ticker.
It is quite easy to do it on a UNIX based system. You can make use of the time command. I've found a very interesting paper that talks about program execution time:
http://csapp.cs.cmu.edu/public/ch9-preview.pdf
Sorry I shouldve added that I'm new to this. Can you please tell me which namespace, class and methods to use in Csharp?
If this is a critical app, consider profiling. There are profilers for all of .NET.
Profilers time each function in your code so you can see where you have problems. There are java profilers as well. Some are free or have trial periods.
google for '.net profiler'
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
