How to Calculate Remaining Charge on a Capacitor After Discharge?
The discussion revolves around calculating the remaining charge on a capacitor after it has been discharged through a resistor. The problem involves a capacitor initially charged to 1 coulomb, with specific capacitance and resistance values, and seeks to determine the charge after a set time interval.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the use of the equation for charge as a function of time in an RC circuit, with some expressing confusion about its derivation and application. There are attempts to calculate the charge remaining after a specific time, with varying interpretations of the exponential decay factor involved.
Some participants have provided guidance on the correct interpretation of the exponential function used in the decay equation. Others have shared their calculations and results, indicating a mix of understanding and uncertainty about the underlying concepts. A participant has successfully arrived at a correct answer, while another seeks clarification on the formula applicable to a different set of parameters.
There is mention of a lack of familiarity with the relevant equations in the course materials, leading to questions about how students are expected to approach such problems without additional resources or guidance.
haxxorboi
A capacitor is charged to 1 coulomb; the capacitance is 8.00×10-5 farads. Then a switch is closed which puts the capacitor in a closed circuit with a resistor; the resistance is 8.60×101 ohms. Calculate the charge on the capacitor after 4.00 milliseconds. (1 ms = 0.001 s)
I=V/R
C=Q/V
C=Q/V=8E-5 F=1/V V=12500 V
I=V/R=12500/86=145.348 A
145.348 C/S = .145348 C/mS
.145348*4=.5814 C transferred in that 4 milliseconds
1-.5814=.4186 C left
So the answer would be .4186 C I think but I'm getting an "Incorrect Answer" apparently
I=V/R
C=Q/V
This is a time varying current flow. You will want to consider the Charge as a function of time.
[tex]Q_{(t)} = Q_o*e^{\frac{-t}{RC}}[/tex]
I've never seen that equation before and I can't find it in our chapter.
Let me see if I understand this equation...
Final charge=1 Coulomb * 1.602E-19-.004/(86*8E-5)
Does that seem right or am I misinterpreting part of the equation.
Thanks
"e" is the natural base = 2.71828..., rather than the charge of the electron, in this case. Just write it as "e", and use the exponental function on your calculator.
This is correct. Not e the charge of an electron. e the natural log
It's typically used to express the decay in RC networks.
SWEET! The answer ended up being .5591 C which was correct with the system.
Thanks so much for the help guys, I feel stupid with not recognizing which "e" that was seeing as this is an exponential decay. I'm not sure how we were supposed to know how to do this problem though as I can't even find this equation in our course pack I have no idea how my Prof expected our Phy101 class to know this without going for help.
Thanks again guys for the help!
I have the same problem but with these numbers
A capacitor is charged to 1 coulomb; the capacitance is 6.00×10-5 farads. Then a switch is closed which puts the capacitor in a closed circuit with a resistor; the resistance is 9.20×101 ohms. Calculate the charge on the capacitor after 4.00 milliseconds. (1 ms = 0.001 s)
what kind of formula do I use to solve this
  • · Replies 31 ·
