How to calculate size of objects in digital photo
  • Context: High School
  • Thread starter Thread starter Suppaman
    Digital Photo
The discussion revolves around calculating the distance between a model and a camera to achieve a specific image resolution, particularly focusing on how to ensure that objects of known size appear accurately in digital photographs. The conversation touches on various aspects of photography, including lens specifications, sensor resolution, and the impact of distance on image quality.
  • Some participants question the premise that one-pixel buttons would not look accurate, suggesting that they may not appear as perfect squares due to various factors.
  • One participant provides a rough calculation indicating that for a 20MP sensor with a 50mm lens, a subject would need to be approximately 194 feet away to achieve a one-pixel representation of a one-inch object.
  • Another participant emphasizes the need for additional parameters, such as aspect ratio, to arrive at a more precise answer.
  • There are discussions about the limitations of formulas in determining image detail, noting that factors like lens quality and file format compression play significant roles.
  • One participant mentions using a laser rangefinder to measure distances and suggests that empirical testing could validate theoretical calculations.
  • Another participant expresses a desire for a formula to calculate the size of the image on the camera sensor, linking it to the resolution needed for specific subjects at given distances.
  • There is a suggestion that turning an algorithm into a formula is left as an exercise for the reader, indicating a level of complexity in deriving a straightforward formula.
Participants express differing views on the accuracy of one-pixel representations and the necessity of additional parameters for calculations. There is no consensus on a definitive formula or method to calculate the desired distance, and the discussion remains unresolved with multiple competing viewpoints.
Limitations include the dependence on specific camera sensor ratios, the quality of lenses, and the effects of image cropping, which are not fully addressed in the discussion.
Photographers, optics enthusiasts, and individuals interested in the technical aspects of digital imaging may find this discussion relevant.
Suppaman
TL;DR
How to calculate the distance in feet between the model and the camera that results in a one inch per pixel for the given parameters.
Please move to a better forum if available.
We have two friends discussing their photography efforts.
"you know that your photo of people with large one-inch square buttons on their coats will not look accurate," said Moe.
"Why is that," asked Curly.
Moe answered, "You have the model standing (feet?) from the 20 MegaPixel camera using the fifty-millimeter lens, and their buttons will show as one pixel in the image. You need to move the camera closer."
How to calculate the distance in feet between the model and the camera that results in a one inch per pixel for the given parameters. What is the formula?
Mathematics news on Phys.org
A couple of things:
1] I'm not sure about the premise of your scenario. Why would 1 pixel buttons not look accurate? Are you perchance supposing they'll look like perfect little squares? They won't - for several reasons.2] You'll only get an approximate answer, unless you were to specify some more parameters, such as aspect ratio.A very rough answer (I know of no formula that could do this):
A 50mm lens is pretty close to how a human sees the world, so we'll neglect lens distortion due to focal length.
A 20MP sensor at 4:3 ratio will have approx 5200x 3900 pixels.
For a scene to render at 1px per inch on that sensor, it would have to subtend 3900 inches (or 325 feet) top-to-bottom.
Using an isosceles triangle calculator, I get a "height" of 325, and a base angle of 50, which gives me a subject-distance of approx. 194 feet.
DaveC426913 said:
A couple of things:
Assume all pixels are used. Full frame.
Yes. No. That does not help.
  • Haha
Just as an image from an orbiting camera has limits on the smallest object it can see, this is sort of the same question. I am looking for a way to tell how much detail will be available using a formula.
I do not think the pixels know how an image may be cropped. Assume the image is not cropped, same size as the sensor.
So a couple test photos will answer this pretty easily. @Suppaman -- have you or your friends taken a few test pictures as a sanity check on any formulas that you hear about or come up with?
When I extend my arm 1 meter out from me and hold my pointer/thumb tips 2mm apart and that matches the height of a 6 foot tall human in the distance, I can figure out how far they are away from me... :wink:
I have a laser rangefinder and a mirror that reflects it back along the same path so I can tell how far away something is. I could take an image of a postage stamp at some distance and look at it in my editor to see how many pixels it covers, But a formula must be available and I do not see how aspect ratio changes anything.
Sorry, I'm not understanding yet. Laser rangefinders work via time-of-flight, not beam spreading. Reflection from a cube corner would affect beam width anyway. How are you wanting your laser rangefinder to operate?
It measures the reflection time and the corner reflector gives me a better range. It works fine.
Great! Then why did you post this?
Suppaman said:
Summary:: How to calculate the distance in feet between the model and the camera that results in a one inch per pixel for the given parameters.
That's a very different question. No formula will tell you that. It's too nuanced.
Depends on the quality of your lens, the compression of your chosen file format, etc.
Of course it is assumed full image.
One of the problems is that 20MP camera will not tell you the format (ratio) of its sensor, so you can't know how big one pixel is. Some ratios are 3:2, some are 1:1.
He's looking to figure out, via formula (i.e without leaving his armchair) how how far away he will need to be to get the subject's buttons larger than one pixel.
DaveC426913 said:
how how away her will need to be to get the subject's buttons larger than one pixel.
With a laser rangefinder? I think I've fallen into the Twilight Zone...
I want a formula to calculate the size of the image on the camera sensor. This tells me how much resolution an image will have, If I know something 100 feet away will require 1000 pixels to show a face I would have to use a longer lens or move closer if the formula said I would only cover 300 pixels.
Yeah, OK. So I guess OP is willing to rise from his/her armchair and seek empirical results.
Not a formula but an algorithm, which I did in post #2. Turning that algorithm into a formula is an exercise left up to the reader.
I am in my late 70s with health issues and Covid is around, I do spend time in my chair writing SF managing my pills and stuff. I am a retired Senior Software Quality Assurance Engineer. Before I retired I was testing time of flight mass spectrometers. Science is one of my hobbies along with photography. I do appreciate your help, all of you.
God the things you must have seen.
  • Haha
It's a geometry problem, and one frequently dealt with by astrophotographers. I'm sure there are sites that will give the full derivation (if you google), but here's one with a rolled-up/simplified equation and a calculator:
https://astronomy.tools/calculators/ccd_suitability
To find what you are after, the "Field Of View" (FOV) and the number of pixels across the sensor are needed.
NOTE: This applies for a fixed lens and sensor combination. If you change lenses or use a zoom lens, you have to re-calculate for each focal length.
  • The number of pixels across the sensor may be the hardest to find.
    • The camera manual or website may list the pixel count.
    • If you have a camera that attaches EXIF (Exchangeable Image File) information to the image data, you can use an image viewing program, or an EXIF viewing program, to read how many pixels wide and high the image is.
    • An image processing program, such as Photoshop, will also report the image size.
    • As a last resort, you can calculate pixel width if you know both the Aspect Ratio of the image and the total number of pixels in the sensor. Aspect Ratio is the proportion of the number of pixels horizontally to the number of pixels vertically. A common aspect ratio is 4:3; that is: if there are 4000 pixels horizontally, then there are 3000 pixels vertically, giving a 12MP sensor.
Now that you know the number of horizontal pixels (4000 in the above example), you need to
  • find the FOV.
    • Take a photo of something horizontal that you can measure the actual size of and fills the full width of the image.
    • Measure the Distance to what you photographed. (you will need this later)
    • The Resolution (smallest descernible feature) at that distance is:
      Resolution = [ (2 × <actual size of subject>) / (<number of horiz pixels)]
For different distances, the resolution scales directly with the Distance you measured above. If you move three times as far away from your subject, then the smallest resolvable detail will have to be three times as big.
Have Fun!
Cheers,
Tom
p.s. Sometimes lenses and/or cameras will state a FOV as an angle. This is the full extent in degrees from the left edge to the right edge of the subject that will be imaged. From that angle, using trigonometry, you can find the same information as calculated above, without having to measure distance or size of the object.
p.p.s. Please keep us updated on your results. Thanks.
  • · Replies 152 ·
12K
13K
  • · Replies 16 ·
  • · Replies 16 ·
