How to calculate the capacity of a disk drive
The discussion revolves around calculating the capacity of a disk drive based on given specifications, including the number of platters, tracks, sectors, and the size of each sector. Participants explore the conversion of the calculated capacity into gigabytes, addressing different definitions of a gigabyte.
  • One participant calculates the number of read/write heads as 12 and the capacity in bytes as 165888000, seeking assistance in converting this to gigabytes.
  • Another participant asserts that the conversion to gigabytes has already been achieved, questioning the need for more significant digits.
  • Multiple participants clarify that there are two definitions of a gigabyte: one as 1,000,000,000 bytes and the other as 1,073,741,824 bytes, introducing the term "gibibyte" for the latter.
  • One participant notes that the definition of gigabyte may depend on the age of the textbook and suggests providing answers in both GB and GiB to avoid confusion.
  • Several participants express gratitude for the information shared, indicating a learning experience regarding the definitions of gigabytes.
Participants generally agree on the existence of multiple definitions for gigabytes, but there is no consensus on which definition should be used in the context of the disk drive capacity calculation.
The discussion highlights the potential for confusion regarding the definitions of gigabytes and gibibytes, as well as the implications of using different conventions in calculations.
TanyaQ
Thread moved from the technical forums, so no Homework Template is shown
Good morning, I got a question like this-
"A hard drive has 6 platters, each platter records data on both sides. There are 3000 tracks of nine sectors each. Each sector stores 512 bytes of data. How many read/ write heads are there and what are the capacity of the drive(in Gigabytes)?"
I understand so far the read/ write heads= 2*6 =12
The capacity of the drive= 512*9*3000*12=165888000bytes
I understand to where they got this answers but its not finish as I need to get it to the gigabyte and this find the capacity of the disk. Can you please assist I don't understand ?
You've GOT it to the gigabyte, given the information you were given.
Why would you need more than 6 significant digits anyway?
Why do you believe that the numbers given are not exact?
A gigabyte is 1,000,000,000 bytes. Does this help?
There are two definitions for GigaByte, one is as @phyzguy says at post #3 and the other is equal to
##2^{30}=1,073,741,824## bytes.
In recent years (starting at around 1998), in order to avoid confusion, new terms were created such as "gibibyte," as opposed to "gigabyte," where
1 gibibyte = 1 GiB = [itex]2^{30}[/itex] bytes = 1,073,741,824 bytes
in contrast to
1 gigabyte = 1 GB = [itex]10^9[/itex] bytes = 1,000,000,000 bytes.
However, -- and this is important --, the "correct" answer may depend on how old your textbook is. This whole kibi, mebi, gibi, tebi, pebi, exbi, zebi, and yobi naming convention wasn't universally adopted by everybody.
For the longest time, "gigabyte" might have meant 1,073,741,824 bytes, or it might have meant 1,000,000,000 bytes, and which one was chosen by the hard-drive manufacturer was whichever one made the product look better.
So my advice to you, @TanyaQ, is whichever convention you use, be sure to back it up with your definition. (Or better yet, just answer in terms of both conventions [GB and GiB] to avoid confusion. :smile: )
Oh, and @TanyaQ,
Welcome to PF! :welcome:
in contrast to
Thank you
TanyaQ said:
Thank you
I never know all these. Now I do. Thank you very much
Sooooo much. Thank you
Yes
10K
11K
