How to calculate the groundness
  • Thread starter Thread starter pixel01
The discussion revolves around the installation of an instrument that requires a ground wire, with a specific groundness specification of less than 0.5V/ms. Participants express confusion over the term "groundness," suggesting it may relate to GFCI specifications and possibly a misinterpretation of voltage measurement units. Clarification indicates that the correct measurement might be <0.5 volts RMS, which refers to the root mean square voltage between ground and neutral. To check this, a voltmeter can be used to measure AC RMS volts at the distribution panel, although it is advised to consult an electrician for safety. The conversation emphasizes the importance of accurate measurements for proper instrument installation.
pixel01
Dear all,
I am going to install an instrument. As usual, it needs ground wire and I have it installed.
However in the specs they require that the groundness is <0.5V/ms. I really do not understand that unit and how do they measure the goundness.
Thanks for any ideas.
Regards
pixel01 said:
Dear all,
Regards
Yeah, that's a new word for me as well. Maybe related to some GFCI spec, since there's a time component to the spec. Can you post a link to the product and datasheet?
Sorry for the late reply. Our lab is going to install an ICP instrument and the customer engineer asks us to prepare some conditions for the installation. About the electricity he wrote: "All the powerlines must have groundness (Ground to Neutral <0.5V ms)"
Sounds like it's just a language translation thing. Thanks for the clarification, pixel.
Don't you mean <0.5 volt rms? Root Mean Square voltage value of AC on the neutral?
Oh, thank you. That's correct, the fax is dim and the 'r' is almost gone.
Anyway, how can I check the 'gound to neutral' smaller than 0.5V ?
Just set your volt meter to measure ac rms volts and connect it between ground and neutral wire at the distribution panel.
You might want to get electrician to do the measurement if you are uncomfortable with the getting into the panels however. Safety first.
Edit: On second thought, maybe the measurement should be made at the instrument location. Maybe someone else here knows where the appropriate place to make it.
  • · Replies 21 ·
  • · Replies 38 ·
  • · Replies 18 ·
  • · Replies 18 ·
