How to Calculate the Percentage of As2O3 in a Bug Spray Sample?
  • Thread starter Thread starter ssb
The discussion revolves around calculating the percentage of arsenic trioxide (As2O3) in a bug spray sample based on a coulometric titration method. Participants explore the chemical reactions involved, the calculations for moles of reactants, and the implications of dilution in the analysis.
  • Homework-related
  • The initial calculation of moles reacted using the formula Moles Reacted = (I*t)/(nF) was presented, with a resulting value of 3.607x10^-5 moles.
  • There is uncertainty regarding the stoichiometry of the reaction, with a participant questioning whether it is a one-to-one ratio or a one-to-three ratio of moles.
  • One participant noted that iodine acts as an intermediate in charge transfer and suggested that the reaction can be assumed as As3+ -> As5+ + 2e-.
  • Concerns were raised about the dilution of the sample and the fact that only a portion of the sample was titrated, which affects the calculations for moles of As2O3.
  • A later reply provided a revised calculation leading to a different percentage of As2O3, suggesting a value of 4.85% based on the adjusted moles of As3+ and the dilution factor.
Participants do not reach a consensus on the correct percentage of As2O3 in the sample, as differing calculations and assumptions about the stoichiometry and dilution are presented. The discussion remains unresolved regarding the final percentage calculation.
Participants highlight the importance of considering dilution effects and the correct stoichiometric relationships in their calculations, indicating potential limitations in the initial assumptions made about the reactions.
ssb
A 3.67 gram sample of bug spray was decomposed in acid. Any As^5^+ was reduced to As^3^+ and diluted to 250.0 mL in a volumetric flask. A 5.00 mL sample of this was added to 125.0 mL of 0.0500 M KI buffered to pH 7. A coulmetric titration was carried out with electrically generated I_3^-, which oxidized As^3^+ to As^5^+ according to the reaction:
As^3^+ + I_3^- ----> 3I^- + As^5^+
The titration required 287 seconds at a constant current of 24.28 mA to reach the endpoint. Calculate the percentage of As_2O_3 (197.84 g/mol) in the bug spray.
moles reacted = (.02425 amps * 287 seconds)/(2 (# electrons) * 9.6482x10^4 (Faraday constant)
moles reacted = 3.607x10^-^5
Question 1) Am I right to assume it is a one to one ratio of moles? or is it a one to 3 ratio? Assuming its one to one then (3.607x10^-^5) * (197.84 g/mol) = 7.136x10^-^3 grams of As_2O_3
If you divide this by the original mass (7.136x10^-^3)/(3.67g) oh and multiply by 100 to calculate percent, I come up with 0.1944%. NOW: I was able to do this with about half of the information given in the original equation. I looked at sample problems in my book and found similar calculations can be done if you are given standard potentials for half reactions. We were given none and I cannot find a standard potential for As^3^+ ----> As^5^+ + 2e^-
Question 2) where am I going wrong here? Thank you so much whoever is able to help me tackle this homework problem
Iodine works only as an intermediate in transfering charge, so you may simply assume reaction going is As3+ -> As5+ + 2e- - you know how to calculate the charge, you should be eable to calculate amount of As.
As moles number seems correct, but it is not identical to the number of moles of As2O3.
You forgot that sample was diluted and only part was titrated.
Moles reacted = 3.607 x 10^{-22}
Since its a 1 to 1 ratio of mol As^{3+} to mol I_3 then there are also 3.607 x 10^{-22} mol of I_3
So I will now solve for grams of As_2O_3
Grams As_2O_3 = (3.607 x 10^{-22}/5.00 mL) * (250 mL) * (1 mol As_2O_3/2 mol As^{3+}) (197.84 grams / mol As_2O_3) = 0.178 grams
0.178 grams / 3.67 grams (original sample size) = .0485
.0485 (100) **percentage calculation** = 4.85%
Does this look good?
Much better now.
39K
13K
