How to Calculate Vout/Vin for High-Pass Filter Using Transfer-Function?
  • Thread starter Thread starter Duave
8 replies · 5K views
Duave
Transfer-Function: "Vout/Vin"
https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-ash3/t1/1656161_10151902951360919_2042068460_n.jpg
https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-prn1/t1/16672_10151902951355919_965456274_n.jpg
"Answer #1: Calculation Of Vout/Vin"
The very last equation is my answer. Am I correct?
https://scontent-a.xx.fbcdn.net/hphotos-ash3/t1/1969246_10151902957535919_1007404817_n.jpg
"Answer #2: Display of log amplitude vs. log frequency"
Does this diagram give what was asked for?
https://scontent-a.xx.fbcdn.net/hphotos-frc1/t1/1958500_10151902957555919_1931978744_n.jpg
"Answer #3: phase shift vs. log frequency"
https://scontent-a.xx.fbcdn.net/hphotos-ash3/t1/1901948_10151902957540919_851749761_n.jpg
Did I answer everything about this high-pass filter?
Thank you
The answers look fine. How did you make the Bode plot diagrams?
It looks to be a picture, since it is slightly transparent you can see the next page through it.
I guess it was more of a 'match the bode plot to the circuit' type of question?
FOIWATER,
This is a whole problem. Can you please look at all eight questions and answers and tell me if you see errors?
Thank you for any help that you can offer.
Did I answer all of the questions correctly and thoroughly? Can you please find any errors, and point them out to me so that I can fix them?
Calculate the input impedance looking directly into the base of the BJT
Calculate the output impedance including the 3.3k resistor
Calculate VB neglecting loading of the bias network by the BJT
Calculate VE neglecting loading of the bias network by the BJT
Calculate IE neglecting loading of the bias network by the BJT
Calculate VB including loading of the bias network by the BJT
Calculate VE including loading of the bias network by the BJT
Calculate IE including loading of the bias network by the BJT
https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-frc1/t1.0-9/1932404_10151940102460919_638617745_n.jpg
1(a): Calculate the input impedance looking directly into the base of the BJT
Zin = (hFE + 1){ZLoad}
Zin = (hFE + 1){R10k
Zin = (100 + 1){10 x 10^3(ohms)}
Zin = (101){10 x 10^3(ohms)}
Zin = {10.1 x 10^5(ohms)}
Zin = {1010k(ohms)}
1(b): Calculate the output impedance including the 3.3k resistor
Iin = [IB + (hFE)(IB)]{R3.3k}/{(R10k)/(100 + 1)} + {R3.3k}
Iin = [(hFE + 1)(Ib)]{R3.3k}/{(R10k)/(100 + 1)} + {R3.3k}
Ib = [(Vin)/(Rb)]{R3.3k}/{(R10k)/(100 + 1)} + {R3.3k}
Iin = [(hFE + 1){(Vin)/(Rb)}]{R3.3k}/{(R10k)/(100 + 1)} + {R3.3k}
Zout = {(Vin)/(Iin)}{R3.3k}/{(R10k)/(100 + 1)} + {R3.3k}
Zout = (Vin)/[(hFE + 1){(Vin)/(Rb)}]{R3.3k}/{(R10k)/(100 + 1)} + {R3.3k}
Zout = {(Rb)/(hFE + 1)}{R3.3k}/{(R10k)/(100 + 1)} + {R3.3k}
Zout = {(10k)/(100 + 1)}{3.3k}/{(10k)/(100 + 1)} + {3.3k}
Zout = 96(ohms)
https://scontent-a-pao.xx.fbcdn.net/hphotos-prn1/t1.0-9/1964785_10151940672820919_881396491_n.jpg
2(a): Calculate VB including loading of the bias network by the BJT
rin = (hFE + 1){R}
rin = (hFE + 1){R7.5k
rin = (100 + 1){7.5 x 10^3(ohms)}
rin = (101){7.5 x 10^3(ohms)}
rin = {7.575 x 10^5(ohms)}
rin = {757.5k(ohms)}
IB = IE/(hFE + 1)
IB = {(VCC/R7.5k)/(hFE + 1)}
IB = {(15V/7.5k/(100 + 1)}
IB = 1.98 x 10^-5
IB = 19.8uA
VB = (rin)(IB)
VB = (757.5k)(19.8uA)
VB = 15V
2(b): Calculate VE including loading of the bias network by the BJT
VE = VB - VBE
VE = 15V - 0.6V
VE = 14.4V
2(C): Calculate IE including loading of the bias network by the BJT
IE = IE/R7.5k
IE = 14.4V/7.5k
IE = 1.92mA
2(D): Calculate VB neglecting loading of the bias network by the BJT
{R150k/(R150k + R130k)} x VCC = VB
150k/(150k + 130k) x 15V = VB
8.03V = VB
2(E): Calculate VE neglecting loading of the bias network by the BJT
VE = VB - VBE
VE = 8.03V - 0.6V
VE = 7.43V
2(F): Calculate IE neglecting loading of the bias network by the BJT
IE = IE/R7.5k
IE = 7.43V/7.5k
IE = 0.99mA
Are there any errors?
Thanks again for your help.
Duave said:
FOIWATER,
You made many mistakes in your answers
Zin = {1010k(ohms)}
Are you sure that RL = 10K?
rin = (hFE + 1){R}
IB = IE/(hFE + 1)
IB = 1.98 x 10^-5
IB = 19.8uA
VB = (rin)(IB)
VB = 15V
VE = VB - VBE
VE = 15V - 0.6V
VE = 14.4V
Very interesting VB = 15V?? Are you training to say that voltage divider magically disappeared?
It seems that you completely don't understand what this loading effect of the bias network by the BJT means.
If you remove BJT from the circuit this two 130k and 150K resistors form a unloaded voltage divider. But in your circuit the base current is loading our voltage divider. Simply you must include the base current in your calculation. Because now upper resistor provide current for the lower resistor and for the base. All you need here is to use KVL,KCL and maybe a Thevenine.
I do not know how to calculate for BJT's
I think now, that the RL = 3.3k
I thought 15V was strange myself,
I don't know how to use KCL, or KVL on a transistor.
Which answers have errors? I would like to fix them
1a, 2a, 2b, 2c, are all wrong.
You do KVL and KCL exactly the same as for normal circuit with resistors and sources.
You simply treat Vbe as voltage source equal to 0.6V. And remember that KCL for BJT
Ie = Ib + Ic; and Ic = Ib*β (you treat the transistor as CCCS) that's all.
For example for this circuit
Vcc = Ib*Rb + Vbe + Ie*Re and since Ie = Ib + Ic = Ib + Ib*β = Ib*(β + 1)
So we have
Vcc = Ib*Rb + Vbe + Ib*(β + 1)*Re and simply solve for Ib
So we have
Thanks Jony130,
you're a big help, I am going to calculate values based on your advice, and I will respond.
Thank you
