pane-rubrics
- 3
Is it possible to use window fans only for dehumidification and cooling 300 square feet condominium ?
The discussion revolves around the feasibility of using window fans for cooling and dehumidifying a 300 square foot condominium without air conditioning. Participants explore various strategies, environmental conditions, and the effectiveness of different fan types in achieving comfortable indoor conditions.
Participants express a range of views on the effectiveness of window fans versus dehumidifiers and air conditioning. There is no consensus on the best approach, as some advocate for fans while others emphasize the need for additional cooling or dehumidifying solutions.
Participants discuss specific temperature and humidity ranges, indicating that conditions may vary significantly. The effectiveness of proposed solutions may depend on individual circumstances, such as room layouts and external environmental factors.
It may not be possible if the humidity and temp outside is the same or higher as the humidity or temp inside. A small dehumidifier might be the best solution on high humidity days.pane-rubrics said:Is it possible to use window fans only for dehumidification and cooling 300 square feet condominium ?
Thanks I am more concerned about nights.Baluncore said:Welcome to PF.
What is the external temperature range and relative humidity?
What temperature range will you accept inside?
Thanks. I believe some type of fans are more effective like ceiling fans and dehumidifier is more environmentally friendly.Tom.G said:For a portable or floor model, be aware that all the electricity it uses ends up as heat within the apartment.
If that would be a problem for you, I recommend either a window or portable air conditioner. The dehumidifier and and air conditioner use exactly the same technology, it's just that the air conditioner dumps the waste heat outdoors instead of in your living quarters.
I live quite close to the Pacific Ocean in Southern California. With central heat & air conditioning - and a portable dehumidifier, - there are always a few days in the summer when both A/C and the dehumidifier are needed.
Also, depending on the room layouts, you might need a box fan to get conditioned air into one of the rooms. With 300 sq.ft. the Low speed of the box fan would likely do the job.
Cheers,
Tom
That of course will work if the outdoor temperature on your 'cooler' side is below your desired temperature.pane-rubrics said:Thanks. I believe some type of fans are more effective like ceiling fans and dehumidifier is more environmentally friendly.
I am hoping to draw air at cooler side of condo and exhaust them at hotter side of condo.
Those numbers are similar to my summer temperatures. So I do not need, or have A/C.pane-rubrics said:1. Highest 28 degree C, Minimum 12 degree C , maybe 83% humidity
Indoor preferably 23 degree C
