How to code the expression with least roundoff error
The discussion revolves around coding a mathematical expression involving complex numbers and logarithms in a way that minimizes roundoff error. Participants explore different coding strategies, potential pitfalls, and the behavior of built-in functions in numerical software.
  • One participant presents a Fortran code snippet for calculating the expression but notes significant roundoff errors with the current approach.
  • Another suggests calculating the sum first and then subtracting it from the logarithm, proposing an alternative formulation that may yield better results depending on the values of z and m.
  • Some participants discuss the impact of summing smaller numbers first to reduce truncation error, questioning whether the common factor z^m can be factored out of the sum.
  • A participant raises concerns about the accuracy of logarithmic calculations, referencing an identity and noting discrepancies when evaluated in Mathematica, suggesting that built-in functions may not always achieve expected precision.
  • There are mentions of issues with NIntegrate in Mathematica, including potential failures to meet precision goals and inquiries about settings like WorkingPrecision and PrecisionGoal.
  • A participant reflects on past experiences with Fortran, recalling difficulties related to precision, especially with complex variables.
Participants express differing views on the best approach to minimize roundoff error, with no consensus on a single method or solution. The discussion includes various strategies and acknowledges the complexity of achieving high precision in numerical computations.
Participants note limitations related to the precision of built-in functions and the dependence of numerical accuracy on input parameters, but do not resolve these issues.
bsmile
The expression to code is: (z complex, m some positive integer)
z^m ( ln(z/(z-1)) - sum( 1/(k z^k), {k=1,m} ) )
The way I code is (in fortran) (in case z<2)
Z_1=1.0_q/Z
ZV1=LOG(Z/(Z-1))
ZK=1.0_q
DO K=1,M; ZK=ZK*Z_1
ZV1=ZV1-ZK/K
ENDDO
ZV1=ZV1/ZK
But it gives quite big error by this bruteforce way of coding. Can anybody help me out to suggest a better way to code it?
Thanks,
Technology news on Phys.org
I would do the sum first, then subtract it from the logarithm. Another possibility is to calculate
z^m \ln \frac{z}{z-1} - \sum_{k=1}^m \frac{z^{m-k}}{k}
Depending on the value of z and m, one approach might be better than the other.
Summing smaller numbers first will reduce truncation error, so this may be better. I assume the common factor z^m can be placed outside the sum, even if z is complex?
##z^m ( \ln \frac{z}{z-1} - \sum_{k=m}^1 \frac{z^{-k}}{k})##
Thanks for your help. I wonder whether the issue comes from Log[z/(z-1)]. To test it, I evaluated two equivalent expressions with Mathematica making use of the following identity
ln(z/(z-1))=∫^{1}_{0} 1/(z-x) dx
Ideally, the difference between left and right hand sides should be zero, but Mathematica tells me otherwise, as shown from the attached figure.
Can you explain to me why as usually we would assume the elementary functions have been extremely well carried out as built-in functions and should attain the highest machine precision?
(how to upload a figure?)
Below the text box, to the right, you should find a botton marked "UPLOAD".
Thanks, I had been clicking on the figure icon on top of the textbox, and it really didn't do what I wanted. Here is the figure showing the two otherwise equivalent expressions have error bigger than machine precision and has a strong dependence on the input parameters.
I understand the precision of the output from the built-in functions will have a dependence on the input parameters, but they should do at least what we ordinary people can achieve. Obviously if |z| is small, we should be able to make it more accurate by using taylor expansion than what gfortran
returns us.
One thing I might mention is that the lack of accuracy can be in NIntegrate as well as it might fail to reach prescribed precision goal I set. I have written to Mathematica to see whether there is way to detect the condition satisfied or not.
Have you set WorkingPrecision as well as PrecisionGoal?
Z_1=1.0_q/Z
ZV1=LOG(Z/(Z-1))
ZK=1.0_q
DO K=1,M; ZK=ZK*Z_1
ZV1=ZV1-ZK/K
ENDDO
ZV1=ZV1/ZK
Thanks,
I have forgotten all the FORTRAN I once knew (good riddance!) but I do remember some hard-to-track-down bugs due to not forcing double precision - particularly with complex variables.
  • · Replies 20 ·
26K
