How to Complete the Inductive Step in a Series Inequality Proof?
  • Thread starter Thread starter sbc824
    Proof
4 replies · 2K views
sbc824
i=1 Sigma n (1/i2) <= 2 - (1/n)
I've done the basic step and assumption step...little stuck on the inductive step
So far I have...
show 1 + 1/4 + 1/9 + 1/16 +...+ (1/k2) + (1/(k+1)2) <= 2 - (1/k+1)
So far I have...
To clarify matters:
I take it that you need to prove (by induction) that:
[itex]\displaystyle <br /> \sum_{i=1}^{n}\frac{1}{i^2}\le2-\frac{1}{n}\ .[/itex]​
Is that correct?
So, you have assumed that 1 + 1/4 + 1/9 + 1/16 +...+ (1/k2) ≤ 2 - (1/k) ,
and you need to show that 1 + 1/4 + 1/9 + 1/16 +...+ (1/k2) + (1/(k+1)2) ≤ 2 - (1/(k+1)) .
Is that correct?
What have you tried, in this effort?
BTW: Please learn to use parentheses, so that your mathematical expressions say what you mean for them to say.
SammyS said:
To clarify matters:
Is that correct?
Is that correct?
Yes, that is correct...I've done equality inductive proofs, but have not encountered less than or greater than type proofs...so I'm not sure how to begin.
The idea is almost exactly the same as equality. Starting from where you left off you have [itex]\sum_{i=1}^{n}\frac{1}{i^2} + \frac{1}{n+1}[/itex]≤ 2- [itex]\frac{1}{n+1}[/itex]
See what happens if you combine like terms and use what you already know about [itex]\sum_{i=1}^{n}\frac{1}{i^2}[/itex] to help you out.
Let's see:
You are assuming that some k,
1 + 1/4 + 1/9 + 1/16 +...+ 1/k2 ≤ 2 - (1/k) .​
Adding 1/(k+1)2 to both sides gives you that
1 + 1/4 + 1/9 + 1/16 +...+ 1/k2 + 1/(k+1)2 ≤ 2 - (1/k) +1/(k+1)2 .​
So, if you can show that 2 - (1/k) +1/(k+1)2 ≤ 2 - 1/(k+1), then you should be able to complete the proof.
