How to convert Antimony Sulfate to Sb2O3?
  • Thread starter Thread starter Panthera Leo
    Convert
The discussion focuses on converting Antimony Sulfate to Antimony Trioxide (Sb2O3) for use as a refining and reducing agent in glass melting processes. Heating Antimony Sulfate at approximately 1200 degrees Celsius will likely decompose it into Antimony (III) Oxide and Sulphur Trioxide. Participants recommend using calcium hydroxide (Ca(OH)2) or barium hydroxide (Ba(OH)2) to precipitate Sb oxide or hydroxide from the sulfate. The conversion is essential for achieving deep green colors in glass, as Sb2O3 prevents undesirable reactions with other oxides.
  • Understanding of chemical decomposition processes
  • Knowledge of glassmaking and the role of reducing agents
  • Familiarity with Antimony compounds, specifically Antimony Sulfate and Antimony Trioxide
  • Basic chemistry skills, particularly in precipitation reactions
  • Research the thermal decomposition of Antimony Sulfate
  • Learn about the role of Sb2O3 in glassmaking
  • Investigate the solubility and precipitation reactions of Ca(OH)2 and Ba(OH)2
  • Explore alternative reducing agents for glass melting
Chemists, glassmakers, and materials scientists interested in refining techniques and optimizing glass color through the use of Antimony compounds.
Panthera Leo
Hi,
I have got some Antimony Sulfate and would like to convert it to Sb2O3 to be used as a refining & reducing agent in glass melt. But I am not sure if using the sulfate as such will decompose in the oxide at high temperatures (around 1200 celsius)... Any help will be highly appreciated.
Is there any other reducing agent you could recommend?
Thanks.
Chemistry news on Phys.org
Heating Antimony Sulphate will likely decompose it to Antimony (III) Oxide and Sulphur Trioxide.
It is supposed to hydrolyze in dilute water to the oxide. Sounds messy to me. Why don't you just get some antimony trioxide instead?
Why reducing? In the sulfate, Sb is in which oxidation state?
Anyway, if the sulfate is water soluble and gives Sb ions and SO42- ions, you could add Ca(OH)2 or, better, Ba(OH)2 (more soluble) and calcium or barium sulfate precipitates giving Sb oxide or hydroxide (or antimonic acid?) and in case you dry the last by heat.
Antimony oxide acts as a reducing agent towards manganese and chromium oxides in glassmaking.
Thanks for the instructions... sounds very interesting indeed...
But I am really scared of touching Sb in aqueous state. I guess I will just add a 0.5% of glass batch the Sb sulfate and see what happens :D
You're 100% correct :)
without Sb2O3 it's almost impossible to create deep/pure green colors (from Cr2O3) generally because sodium oxide and chromium oxide react to form sodium chromate which gives the glass a yellowish tint.
If there's a tiny amount of PbO in the batch, lead chromate will form making the glass brownish orange instead of green !
Both cases can be avoided with the addition of Sb2O3...
I wish, I could ... I have searched every single chemical shop in town but non of them is offering the oxide for sale! all I could find was the sulfate.
  • · Replies 46 ·
  • · Replies 19 ·
9K
