How to convert from hex to dec ?
  • Thread starter Thread starter tinhnho
    Convert
Hexadecimal numbers consist of 16 symbols, with each digit representing a power of 16. To convert from hex to decimal, multiply each digit by its corresponding power of 16, starting from the rightmost digit. For example, the hex number 30500000 converts to decimal by calculating 0 + 0*16^2 + 0*16^3 + 0*16^4 + 5*16^5 + 0*16^6 + 3*16^7, resulting in 1052672. Users can verify their conversions using online calculators for accuracy. Understanding the positional values is crucial for correct conversion.
tinhnho
edited..thanks for your help
Mathematics news on Phys.org
First, note that hexadecimal has 16 symbols (0-9, followed by 'A,' equal to decimal 10, through 'F,' equal to decimal 15).
The first digit on the right is the one's place. Take whatever number is in that position, and multiply it by one.
The next digit, second from the right, is the sixteen's place. Take whatever numer is that position, and multiply it by 16.
The next digit, thrid from the right, is the 256's place. (256 = 16^2.) Take whatever number is in that position, and multiply it by 16.
The next digit, fourth from the right, is the 4096's place (4096 = 16^3.) Take whatever number is in that position, and multiply it by 4096.
Add the result of all those multiplications, and you have the number in decimal.
- Warren
here what i have for Hex 30500000 => Dec = 1052672
(16^3 + 16^5= 1052672)
my result seem doesn't right !:confused:
I confuse, would you give a example by number instead by words? Don't need to be exacted those hex number above, any number would fine with me, i will follow from there and try to undestand. Again thanks for your explanation.
nevermind, i think i got it
here what i did 0x1 + 0x16 +0x(16^2) + 0x(16^3) +0x(16^4) +5x(16^5) +0x(16^6) +3x(16^7) =810549248
the result matchs with the calculator. thanks :)
The answer should be:
0 + 0*162 + 0*163 + 0*164 + 0*165 + 5*166 + 0*167 + 3*168 = 12968787968
Oops I lost a digit disregard my last post.
Hi guys,
In case you want to double check your results, use this http://www.stringfunction.com/hex-decimal.html"
Hope this can help
David
