How to correctly type "-i.e." in LaTeX?
  • Context: LaTeX
  • Thread starter Thread starter Haorong Wu
The discussion revolves around the correct formatting of the term "-i.e." in LaTeX, particularly in the context of manuscript submissions and editorial modifications. Participants explore various ways to type this term correctly, considering both LaTeX syntax and editorial preferences.
  • Technical explanation, Debate/contested, Meta-discussion
  • One participant notes that their manuscript was edited to replace ",i.e." with "-i.e.," and seeks clarification on how to type it correctly in LaTeX.
  • Another participant suggests that it is not necessary to use LaTeX for "i.e." and provides a method using four hashtags.
  • Several participants propose different LaTeX commands, such as \text{,i.e.,} and \text{-i.e.,}, while expressing confusion over the original post.
  • One participant suggests that communicating directly with the editor may be more effective than seeking advice in the forum.
  • A suggestion is made to create a macro for "i.e." to facilitate easier formatting throughout the document.
  • Another participant points out a minor formatting issue regarding spacing after the first comma in the term.
Participants express differing opinions on the correct formatting and usage of "-i.e." in LaTeX, with no consensus reached on a single correct approach.
There are unresolved questions about the specific requirements of the editor and the potential variations in formatting preferences.
Haorong Wu
Last year, I submitted a manuscript to PRD. I noticed that all ",i.e.," are modified into "-i.e.," by the editor.
Therefore, in my recent manuscript, I typed "---i.e.," in LaTeX. However, all the "-i.e.," are modified again into "-i.e.," by the editor. I could not distinguish the difference between them.
So, how should I correctly type "-i.e.," in LaTeX? Thanks.
Do you mean "Id est"? What software are you using?
Anyhow, at PF it is not needed LaTeX to type ie; but in case you needed, it should be four #, and ie in the middle; ie, ##ie##..
Hope it helps.
\text{,i.e.,} is one way, which looks like this:
##\text{,i.e.,}##
or did you want ##\text{-i.e.,}##? Your post was a bit confusing about that.
##\text{,i.e.,}##
Very sorry for the confusion.
In my manuscript last year, I typed ",i.e." in LaTeX. However, in the proofs, I notice that they are all replaced by "-i.e.," by the editor, as in the following figure.
Therefore, in my recent manuscript, I typed "---i.e.," in LaTeX. However, in the proofs, they are again corrected by the editor, as in the following figure. I could not tell what was done by the editor.
Maybe I should type "--i.e.,"?
Maybe you should type "\text{,i.e.}" ?
I would suggest just communicating with that editor to ask how they want it done. That seems like a more productive path compared to asking us. :wink:
Make a macro, e.g.,
\newcommand{\ie}{\textit{i.e.}}
It will be easier to make a global change throughout the document.
Of course, you can modify it as you wish... or as the editor wishes.
##\text{,i.e.,}##
Minor nit: there should be a space after the first comma, i.e., ##\text{, i.e.,} \dots##
  • · Replies 20 ·
  • · Replies 16 ·
