How to decrement vector elements and handle negative values in C++.
  • Context: C/C++
  • Thread starter Thread starter needOfHelpCMath
    Elements Vector
1 reply · 4K views
needOfHelpCMath
I am stuck on now to decrement the numbers and would like some help please.
Write a loop that subtracts 1 from each element in lowerScores. If the element was already 0 or negative, assign 0 to the element. Ex: lowerScores = {5, 0, 2, -3} becomes {4, 0, 1, 0}.
Code:
#include <iostream>
#include <vector>
using namespace std;
int main() {
   const int SCORES_SIZE = 4;
   vector<int> lowerScores(SCORES_SIZE);
   int i = 0;
   lowerScores.at(0) = 5;
   lowerScores.at(1) = 0;
   lowerScores.at(2) = 2;
   lowerScores.at(3) = -3;
   /* Your solution goes here  */  for (i = 0; i < SCORES_SIZE; ++i) {
if (lowerScores.at(i) < SCORES_SIZE) {
lowerScores.at(i) = 0;
      cout << lowerScores.at(i) << " ";
   cout << endl;
   return 0;
Testing for lowerScores = {5, 0, 2, -3}
Expected output: 4 0 1 0
Your output: 5 0 2 0
In the following for-loop:
Code:
You have code that will set the array value to zero if the value there is less than [M]SCORES_SIZE[/M]. However, what you want is code that will set the array value to zero if the value is not positive, otherwise you want to decrement it. So, I would try something like:
Code:
for (i = 0; i < SCORES_SIZE; i++)
	if (lowerScores.at(i) > 0)
		lowerScores.at(i)--;
	else
